[ Total Views: 501 | Total Replies: 8 | Thread Id: 22870 ]
Author: Subject: 36mm webers 40mm webers
Memberwaltermitty
Mood: Hungry for mor
posted on May 13th, 2004 at 04:29 PM
I have a set of twin 36mm webers which I am about to sell as I need some 40s or 44s . It has a set of CB? washable filters on alloy bases which are incorporated with the hexbar linkage. Can I keep the filters and linkage? will they suit 40s? what about the manifolds? are they interchangeable (doubtful)
Thanks Gurus Mitchell:cool:
23 windows ...8 too many!
posted on May 13th, 2004 at 05:55 PM
All interchangeable Mitch
36 - 40 and 44's are all the same bases.
You only need to change the carbs themselves.
Barry
Memberwaltermitty
posted on May 13th, 2004 at 08:23 PM
Cheers Barry. Mitchell
Memberlugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
posted on May 14th, 2004 at 01:04 AM
What are you buildin Mitchell?;)
Memberwaltermitty
posted on May 14th, 2004 at 03:58 PM
I have a set of 90.5 p and b with matching 040 heads, as well as 1.4:1 ratio rockerscso probably a 1776 unless i stroke and I know that that is limited also as I have 'a' pistons or 'b" but standards anyhow not stroked.
I am still not sure what i will end up with just the best i can manage I spose my buget is limited . I do know that even if its a standard crank and it ends up as a 1776 that the 36 mm webers will not be big enough.
Mitchell
MemberOZ Towdster
A.k.a.: Andrew Westwood
Keen to finish some projects
Threads: 132
posted on May 14th, 2004 at 06:26 PM
36'S should be fine on a 1776,check your choke sizes PS i would consider 44'S to big on that size motor.
posted on May 14th, 2004 at 07:51 PM
having run 36's on both 1600 and 1776 and hearing that 36's "should" be ok on a 1776 i say that they are not.
I always had troubles with the 1776 but were smooth as on the 1600.
I was running 32 vents and all sorts of jets.
By the dyno it was perfect.
NEXt time i will run 40's
Memberwaltermitty
posted on May 15th, 2004 at 01:05 AM
barry glad to hear that you are contemplating 'next time
Mitchell
Membervassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
posted on May 16th, 2004 at 05:09 PM
I ran 36's (with 32 chokes) on my 1776 for a couple of years. Worked a treat. Good mileage and smooth.
Isn't it really the valve sizes that dictate the choke size, therefor carbs that you need to run.
That's my understanding, but I am willing to learn.
:thumb
Marcus
posted on May 16th, 2004 at 08:11 PM
Cant help myself Mitch
To bloody stoopid for my own good.
MemberDaniel
Threads: 9
Mood: Low
posted on May 17th, 2004 at 09:54 AM
What would be the largest you could go using the 40's?
When it comes rebuild time for me I was thinking of going to a 2110. I know there's lots of variables but would they work on anything larger than this?
[ Queries: 40 ] [ PHP: 2.8% - SQL: 97.2% ]
