[ Total Views: 840 | Total Replies: 0 | Thread Id: 23844 ]
Author: Subject: Body off and hinge pins
MemberJeza
Threads: 23
Mood: Spinning
posted on June 3rd, 2004 at 06:43 PM
Hello
2 questions:
I am considering getting a heater channel replaced in my 71 1302- and the place I am talking with wants the body lifted off the floor pan about 200mm - so not a complete body off but lifted.
I am wondering if I can get away with leaving things like the fuel tank attached (I'm pretty sure I've got enough length in the flex hose from the tank to the tunnel) and the steering attached? And the engine in place?
Anything else I should consider?
The cars interior is stripped out, guards and bonnet are off, glass is out, doors are off- But suspension, steering, motor etc are all intact.
And #2
Has anyone replaced their door hinges using one of those oversized hinge pin kits? Is it do-able with hand tools or is a drill press job that I'd be better to let the engineer do?
Jeremy
MemberMidnightOval
A.k.a.: Andrew
Threads: 4
posted on June 3rd, 2004 at 07:54 PM
I haven't replaced hinges, however was thinking about getting the passenger side done. Everyone I spoke to suggested it wasn't a job to do at home. A three person job. One to hold the door, one to heat the hinge and one to beat the crap out of the pin. There is also a chance of breaking the hinge of the door. I still haven't been game as our paint job is too precious.
A panel beater friend mentioned that he had a hinge pin puller. This may be the better option.
MemberJeza
Threads: 23
Mood: Spinning
posted on June 4th, 2004 at 06:04 AM
Thanks for the info MidnightOval, this bit I think I'll leave to the engineering shop.
As for the body off bit I found a vw trends article on line here:
http://www.vwtrendsweb.com/tech/0406vwt_super/
I think I may try to separate the steering at the centre tie rod (its a super), but the article pointed out brakes (ie fluid reservoir), accelerator cable, starter motor and engine wiring.
Jeremy
Kinda answered my own question - so now its a resource :)
[Edited on 3-6-2004 by Jeza]
[ Queries: 40 ] [ PHP: 10.2% - SQL: 89.8% ]
