[ Total Views: 1137 | Total Replies: 1 | Thread Id: 24044 ]
Author: Subject: ABs or not
Member71superbug
The Itch Itcher
Threads: 72
Mood: Subified
posted on June 7th, 2004 at 10:18 PM
ABs or not
hey. i am curious. is it possible to use the falcon brakes from a EB S-pac. which uses ABS. ??. even if u do not use the ABS. can you just use the discs?. onto a 71 BEetle?
Memberseagull
Threads: 752
posted on June 7th, 2004 at 11:06 PM
yes yes yes yes yes
[Edited on 7-6-2004 by seagull]
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on June 11th, 2004 at 11:40 AM
The front calipers will NOT fit as they do not have the standard PBR style mounting system.
They use a 2 bolt system: 1 on the horizontal plane as per VWs and 1 on the vertical plane. So mounting them would very difficult given that welding of brake components is illegal in Australia. Maybe look to other cars, like Nissan or Mazda or Holden (though holden rear calipers are a problem!).
FUCH your early!
http://www.noh2o.org/
Memberhazet
Threads: 19
posted on July 24th, 2004 at 09:49 AM
welding is not illegal as long as you get it welded by a pro and that it's x rayed.
I had a set of welded dropped spindles on a car that went thru the pits,i had to get them x rayed and then it was ok.
( about 5years ago) :sandrine
[ Queries: 40 ] [ PHP: 7.7% - SQL: 92.3% ]
