| [ Total Views: 512 | Total Replies: 5 | Thread Id: 24228 ] |
RENNWAGEN
A.k.a.: shane
Threads: 43
| posted on June 11th, 2004 at 08:50 AM |
Copper in fuel system
Can you use copper pipe in a fuel system or are there strength/corrosion issues? I only ever read of people using aluminium, SS or mild steel.
kombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
| posted on June 11th, 2004 at 08:55 AM |
I have had copper fuel lines in my Humber for at least 6 years no probs, it was normal up until at least the late '50's
| Error |
Please, I need drivers side window regulator (winder mechanism) for my '54
blutopless2
DAMSLO
Threads: 187
| posted on June 11th, 2004 at 10:39 AM |
copper was used as fuel lines for alot of cars. it gives relative strength and yet can handle small amounts of flexing. if you want something with
more strength go steel or SS. Am going to replace the fuel line from the tank to the engine bay in my 65 beetle. I will be using SS tubing and for
the flexible line to the tank i will use SS braided hose etc.
see.... air and water do mix
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
Adam_C
Threads: 164
Mood: could be lower
| posted on June 14th, 2004 at 08:01 PM |
copper tends not to be used as it work hardens, ....... just becareful when bending and constant checks and youll be fine,
Adam
Adzslick@iprimus.com.au
type_one
Threads: 166
| posted on June 15th, 2004 at 01:21 PM |
Check the use of copper with the RTA. I seem to remember it being illegal as copper has a tendency to crack if too much pressure is applied i.e. when
you jump hard on your brakes. Thats what i was told years ago anyway. |
Adam_C
Threads: 164
| posted on June 15th, 2004 at 03:07 PM |
yeh, it becomes brittle from the work hardening and so after a few years maybe you get hard on the anchors and she explodes
Adam
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on June 15th, 2004 at 05:36 PM |
yes , it used to be commonly used in brake systems because of ease of shaping & corrosion resistance - but is now illegal in this application,
& rightly so, not only was there a danger of cracking, it was easly accidently crushed to almost zero I.D. by accidental impact from a tool or
stone or wombat etc
pete wood
posted on June 15th, 2004 at 05:55 PM |
Copper bad
I put new fuel lines through my buggy to cope with the change to a Subaru EFI motor. The Rego engineer I have said a big no to copper. I will work
harden and crack, especially in hiph pressure use.
Go to pirtek and ask about High pressure, cold-drawn, Mild Steel tube. It comes in different sizes and is cad plated. It costs a bit, but how much are
the lives of ya family and friends worth?
P.s the RTA don't like it either.
