[ Total Views: 433 | Total Replies: 11 | Thread Id: 24402 ]
Author: Subject: Thermostat Can I live without one
MemberMidlife crisis
Mood: Wornout and Toxic
posted on June 15th, 2004 at 01:03 PM
Hi everyone
The motor in my Type3 over heated real bad and stop. ( the wife was driving to work )After winding over for a little while it started with a cloud of white smoke. It sounds ok but don't want to take the risk of causing more damage so I am putting another engine in itand pulling this one down to have a look.
The replacment engine has had the thermostat and the flaps in the fan housing removed. As I understand how this works the flaps are closed untill the engine warms up and the thermo opens the flaps. So does it matter if they have been removed. will this mean that the engine will take longer to warmup?. and nothing else and will be ok to drive like this.
thanks for any input
Marc
[Edited on 16-6-04 by Midlife crisis]
MemberRISKY^VW
Threads: 61
Mood: RISKY IS 1337
posted on June 15th, 2004 at 07:56 PM
sorry i don't know!
but where is the thermostat on a vw??
http://www.austech.info/forums
The best tech forum around
oh sgetty will you respect me in the morning
things could be worse you could live in kentucky
posted on June 15th, 2004 at 08:06 PM
It is under the barrels but abve the tinware that goes between the heater boxes and the sump and there is a arm and spring on the right head that has a lever that goes to the flaps in the fan housing
Marc
MemberChe Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
posted on June 16th, 2004 at 12:19 AM
Its ok if the actual thermostat bellows isnt there, it only warms up slightly quicker with it. Its more important that the flaps are there I think, because they direct the air to the heads
Jon
MemberPurple Martin
A.k.a.: Martin
Threads: 141
Mood: warm & fuzzy
posted on June 17th, 2004 at 01:12 PM
Your engine will take longer to warm up without thermostat and flaps. It won't overheat (unless there's another unrelated problem that would cause it to overheat anyway).
The thing is that you engine will wear out quicker if it takes longer to warm up, because most wear happens while the oil is not warm enough.
1959 red & white Beetle
1975 Kombi camper
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on June 17th, 2004 at 01:23 PM
just rip the flaps and other related stuff out and run like 90% of the vw's in OZ. Not realy required unless you are a purist. If it is cold take it easy until it warms up. The difference in engine wear is not worth worrying about (my opinion).:bounce
tssnq.com.au
posted on June 17th, 2004 at 02:34 PM
Thanks peoples for input hat you said is what i thought but wanted to be sure
thanks again
Marc
MemberDesert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
Mood: I don't know if I'm indecisive
posted on June 17th, 2004 at 02:41 PM
I'm with Mick H ...
I take them out before I have a problem with them. If they stuff up like yours you will do more damage then not having them in the first place.
http://img.photobucket.com/albums/v252/Moose906/Sign.jpg
posted on June 17th, 2004 at 02:45 PM
Thanks desert Moose
I took your Idea and made up some joiners for the j pipes
thanks
Marc
[Edited on 17-6-04 by Midlife crisis]
MembermnsKmobi
Threads: 27
posted on June 17th, 2004 at 04:46 PM
Need for flaps/thermostat/etc depends on where you'll be driving. As long as you don't plan going somewhere cold you'll be fine!
Memberfranko
Threads: 20
Mood: cruze-e
posted on June 17th, 2004 at 10:45 PM
try buying a new one anyway,nah mate cant get em anymore. a bit like crabs, everyone used to have em but for some reason theyve disappeared!
if its a kombi and its going too slow, just relax its having a go!
MemberDesert Moose
A.k.a.: Chris Hill
Cut Cut Cut
Threads: 175
posted on June 17th, 2004 at 11:53 PM
Originally posted by Midlife crisis
Thanks desert Moose
thanks
Marc
Cool. Ya gota luv a bit of butchery.....lol, if it keeps you on the road :thumb
posted on June 18th, 2004 at 09:14 AM
Nothing beats a bush mechanic if it does'nt fit get a bigger hammer
thanks everyone for your advice
Marc
Member57 Panel
Threads: 56
posted on June 18th, 2004 at 10:07 AM
engine tin
I'm not sure about a type 3 engine but you have to have the left hand side flap fitted and held in the down position to direct air over the oil cooler. Without it the air bypasses the oil cooler and takes the easiest path out of the engine which makes your engine run hotter.
[ Queries: 40 ] [ PHP: 2.9% - SQL: 97.1% ]
