| [ Total Views: 632 | Total Replies: 17 | Thread Id: 24769 ] |
Kruizin_76
Threads: 6
Mood: Kruizin SLOWLY
posted on June 21st, 2004 at 09:14 PM |
how do i squeeze more HP out of a stock 2ltr?
Howdy fellow dubbers,
just after a bit of guidance,
i have a recently (6 months) rebuilt 2ltr stock motor in my '76 bus, i was after slightly more HP (although more than happy with what i have) mainly
in the bottom end of the rpm, also a higher top speed, currently sit between 90-100 on freeway,
my bus is lowered round 4 inches, and i run on 215/60r14's,
any ideas would be great, looking at up to $1000 to spend???????????????????????????????????????????????? |
Bizarre
| posted on June 21st, 2004 at 09:19 PM |
Strip it???
Seriously- take weight out.
Otherwise for the budget a set of Webers or Dellortos would help
Next its head work, cams and exhaust
Kruizin_76
Threads: 6
| posted on June 21st, 2004 at 09:37 PM |
i was thinking about webers,
while speaking to people they have said you will only wreck your motor?????? im sure many people have done this, again any help or guidance would be
great |
Golde60
Threads: 73
| posted on June 21st, 2004 at 10:08 PM |
power
twin carbs wont wreck your engine
as for head work - from what i can gather, best to start with the exhaust ports when doing t4
also, exhaust.
i will be doing all the above, but will probably wait a while for the heads.
will be watching this post eagerly for any more advice too.....
Golde60
Threads: 73
power
also, exhaust.
Peter Leonard
Volatile
Threads: 52
Mood: shiny
| posted on June 21st, 2004 at 11:16 PM |
easy. twin plug the bastard. you also end up with a solid state ignition with no more burned points and TWO COILS!!
let sleeping dubs lie
type3kid
A.k.a.: Aaron
Mood: evolving..
| posted on June 21st, 2004 at 11:19 PM |
turbo??
can be cost effective and gets you power, just don't rely too heavily on the reliability.
just my opinion, plus i think a sneezin dub kicks ass!
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on June 22nd, 2004 at 08:37 AM |
Seriously, 76, if you can only get 90-100 kmh out of a freshly rebuilt 2 litre kombi, there is something wrong. Don't go searching for performance
mods until you have elimated any existing problems....
Kruizin Kol
Kruizin_76
Threads: 6
| posted on June 22nd, 2004 at 09:02 AM |
the old beast can go harder, ive just been told this speed is about right,
any harder you will drive her into the ground........... aaaaaaahhhhhhhh |
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on June 22nd, 2004 at 09:30 AM |
Mmmm... I'd agree with that if it were a 1600, but a fresh 2lt with everything working the way it should is more than capable of handling 100-110 kmh
on the highway. Sure, I'd slow down a bit if it's really hot, hilly, or when towing or carting a decent load, just in the interests of engine
longevity, but heat problems can be fixed with oil coolers & elephant ears.
Putting performance gear such as carbies and extractors on your kombi is not going to make the engine last longer, just because it has more power in
reserve. In fact, it will probably have the opposite effect, because the components that are still stock will be under more stress with the extra
power and heat you will develop with a modified motor.
My reco'd 1800 is capable of sitting on 110-120 kmh all day without overheating. Admittedly, I don't have a temp gauge, so I can't give you actual
figures for operating temperatures, but I do know what an overly hot VW engine smells like, and mine doesn't overheat even when pulling a trailer.
The one thing I have changed on my kombi is the rear tyres. I firmly believe that constant high revs will kill a motor, so mine now sits on approx.
3000 rpm @ 100 kmh. At this speed, the motor is noticably quieter, and lopes along quite comfortably. On my recent trip to Bendigo I sat on 110-120
kmh with no hassles.
Sure, my tyres are overkill for most people, and the bus does suffer a little from a standing start, and won't hold top up some of the hills that it
did with the 205/60-15's I was running before, but I think you have some benefits to be gained by fitting tyres that are closer to stock O.D. They
won't fix the bottom end power problem, but they will decrease the revs at highway speeds.
Kruizin Kol
mnsKmobi
Threads: 27
| posted on June 22nd, 2004 at 09:41 AM |
Kruizin_76,
Read my post on this thread.
http://www.aussieveedubbers.com/forum/viewthread.php?tid=24447
Short answer to both your questions (power and gear ratios) is that your tyres are too small.
Kruizin_76
Threads: 6
| posted on June 22nd, 2004 at 03:20 PM |
thanks guys better go looking for some 16's then, maybe 215/55r16 or something???
i have twin carbs at the moment, quite happy with the setupo at the moment, i suppose everyone wants more power, just squirting up steep hills seems
painful |
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on June 23rd, 2004 at 10:17 AM |
You may find my post in Member's Rides interesting.
My tyres are overkill for most people's needs, but the wheels may be exactly what you're after.
Kruizin Kol
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on June 23rd, 2004 at 11:04 AM |
A two litre box like what we have got should give 3000rpm at 100kph. This seems to be a nice rpm/speed combo and like Colin's kombi, does not appear
to be overheating. In fact after driving on the highway the air shroud on the engine is cool to touch.
We regularly cruise 110kph on the freeway no probs.
Kruizin_76
Threads: 6
| posted on June 24th, 2004 at 09:04 AM |
thanks guys for the response TOP SHELF WORK!!!!! Helbus do you still get a nice ride on your rims? what size and tyre dimensions have you got? my bus
is 4 inches closer to earth now but will bring the front down further once ball joints get redone, i dont want to kill the kidneys with a terribly
rough ride |
helbus
A.k.a.: Pete S
Threads: 312
| posted on June 24th, 2004 at 09:23 AM |
Nice Ride!
The handling increased dramatically in a positive way.
Before we had stock rims with 185/75/14 Bridgestone somethings. Nice quiet tyres.
The rims now are aftermarket 16x7 with Potenza 205/55/16 tyres. It was only about 8mm height difference. The ride is slightly tighter, a little bit
more road noise.
The biggest advantages are the cornering was improved massively and the braking was better with less dive.
Kruizin_76
Threads: 6
| posted on June 24th, 2004 at 10:09 AM |
yeah great, looks like ima getting some 16's....... HOORAY now the missus cant complain as i will keep up with her on the freeway :thumb |
david
Threads: 157
Mood: amicable
| posted on June 24th, 2004 at 01:47 PM |
and a little help from paint shop
have you looked at your accelerater ,make sure you are getting full acceleration my bus was only getting a little over half throttle
Kruizin_76
Threads: 6
| posted on June 25th, 2004 at 01:01 PM |
thanks David, i will adjust it this afternoon, is there another adjuster to make the pedal sit more upright? i know this isnt the prob but may aswell
adjust anyway |
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on June 25th, 2004 at 06:16 PM |
You should be able to play with the length of the flat linkage that connects the pedal to the linkage that runs across the floor. You can then set the
pedal angle to anything you want... it's a very simple mod.
Kruizin Kol
