[ Total Views: 914 | Total Replies: 17 | Thread Id: 25495 ] |
killakornkobb
A.k.a.: Damien
where's that clutch?
Threads: 149
Mood: Pierced
posted on July 4th, 2004 at 12:42 PM |
Moulding Badges..
does anyone know a good method of making a mould of a badge? the VW badge font is impossible to replicate, and i would like to make a mould of my
badge incase of theft.. as it is possible the only one in Aust.. and i would like to get one up to scone NSW for Lee
i was thinking a 1 piece mould of the front in plaster of paris, and filling with aluminium.. is this possible? i know nothing about melting down
aluminium or plaster of paris.. but they came to mind pretty quickly. the badge i want to replicate has a script font in it also.. so VERY difficult
to "copy" from sight.
if successful, might be worth making moulds of all known VW badges incase one needs to be replicated pretty cheaply
any ideas? any input very welcome!
Tagedeezee Heezy
BiX
Threads: 154
posted on July 4th, 2004 at 01:08 PM |
what baout getting a digital (read electronic outline) outline made , which then can be used for cutting new badges using laser/waterjet?
you may even be able to do this form a good quility photo?
Go hard or go home!!!!
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 4th, 2004 at 01:15 PM |
are you able to replicate the tapered edges that way though? the badges arnt 2d.. yanno what i mean?
Tagedeezee Heezy
BiX
Threads: 154
posted on July 4th, 2004 at 03:09 PM |
yep i know what you mean. you may be able to if you get a good draftsman to do it. and get it drawn in 3d then you just need a lazer cutter that works
in 3d.
might be easier to mould it. what baout talking to professional caster/forgers?
what baout sand moulding?
baybuscamperkid
Threads: 335
Mood: transported
posted on July 4th, 2004 at 05:46 PM |
i have an article somewhere on a liquid rubber made especially for this purpose. just sink your badge into it, let it dry, then remove your badge and
pour some metal (pewter or similar) and u have a new badge.
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 4th, 2004 at 07:23 PM |
bay bus could u look that up for me?
Tagedeezee Heezy
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 11th, 2004 at 06:07 PM |
wwell i'v tried plaster - dosent work ..
emptied a whole tube of silicon sealant into a tray and stuck thebadge in.. will give it a week or so.. probably even longer untill it sets, then i
will try filling the mould with a metallic filler.. if that fails, i'll get somone else to make up like 50 or so
Tagedeezee Heezy
baybuscamperkid
Threads: 335
Mood: transported
posted on July 12th, 2004 at 12:20 PM |
Performance Buildups Vol-3 No-2
3120 RTV or Elastosil M4470 with T37 catalyst - rubber for the mould
chemical mould release to get the original back out
Talcom powder the mould so metal doesnt stick
JA12 (can be chromed) or Pewter (cannot be chromed) - metal for new badge
beneath the article is an add for Solid Solutionsin Bentleigh Vic (tel. 95790573) who can probably give you better qadvice and provide the equipment
to set you up.
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 12th, 2004 at 06:29 PM |
thanks cheif
Tagedeezee Heezy
1303Steve
posted on July 12th, 2004 at 09:52 PM |
Ive seen a few of those badges at swaps, they were fitted to imported cabrios I guess. Richard @ V Force (Alexs dad) has been getting some cool
badges profile cut, like VW2232 etc.
1302Steve
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 13th, 2004 at 06:50 PM |
the badge i have is from the first 6 months of the 68 production year of Auto-Sticks in Germany (all auto sticks were made there.. and only the VERY
first 6 months worth have the badge)..
the rest changed to VW-Automatic.. some others are around in Oz ihaveheard.. but not in one piece unfortunatley
im lucky enough to have a whole one, with the VW logo on the back, with part number.. so i know it is an original, not a repro..
the plan is to make some up, to keep on the car, keep the real one safe, and get one out to anyone with an Auto-Stick who would like one
Tagedeezee Heezy
Clintooo
Threads: 0
posted on July 14th, 2004 at 11:47 AM |
This isn’t really an answer, but it is the best I can do.
I remember watching on Cruzin (Hot rod show on channel 31 in perth) a segment on a product that will let you replicate badges and other plastic trim
pieces. It was a two step process.
Make the mould with a two part epoxy like playdoh, just press the badge into it. It hardens in a couple of minutes.
Then I think you pour another epoxy into the mould and pop it out when it is dry. The finished product is then paintable etc.
However, that is as far as my memory goes. I cant remember what it was called. I have tried a google search for it but I couldn’t turn anything
up.
Maybe someone else can remember something about it.
Clint |
Vw nutter
Threads: 148
Mood: Chillin
posted on July 15th, 2004 at 02:31 PM |
maybe you could make a mould out of plasta and then fill with pewter? might work ive dont it before with other similar things.
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 15th, 2004 at 07:07 PM |
Quote: | Originally
posted by killakornkobb
because of the script it gets stuck very eaisily, and how fragile the badge is, it is impossible to get it out of the plaster, with out breaking the
plaster off it..
almost snapped the badge trying to get it out
Tagedeezee Heezy
Vw nutter
Threads: 148
Mood: Chillin
posted on July 16th, 2004 at 01:27 PM |
maybe you could get some sort of spray or grease that make the badge come off the plaster and doesnt stick to it, might work, maybe vaseline, i dunno
really but i hope u find a way.
Whitty
Threads: 28
Mood: so happy I could shit
posted on July 16th, 2004 at 04:25 PM |
If you can find someone that does sand moulding and casting, they will have a new one made that is identical to the original in about 2hours tops. I
work at an aluminium smelter, and used to "find" a whole heap of scrap
aluminium for a bloke in town who had his own mini cast shop in his shed. He could melt it down and cast it to any shape you wanted as long as he had
something to copy - ie. could make a sand mould of the object. No harm done to original and new one a perfect replica. I'm sure in the sunny
metropolis of Melbourne you would be able to find someone doing the same sort of hobby out of their backyard.......
killakornkobb
A.k.a.: Damien
Threads: 149
Mood: Pierced
posted on July 16th, 2004 at 06:48 PM |
im going to try and do the plaster again.. but put some glad wrap over the soft plaster before i push the badge in.. but first i have to get all this
damn silicon off the badge i tried the other night after work.. but the
turps smell pissed everyone off
Tagedeezee Heezy
Adam_C
Threads: 164
Mood: could be lower
posted on October 9th, 2004 at 03:47 PM |
maye, duno if youve looked, but classic vw make repro badges like that
Adam
Adzslick@iprimus.com.au
ancientbugger
Threads: 191
posted on October 10th, 2004 at 07:53 PM |
If you know of any old hot metal printers around they could make a neg of the badge and then produce what was called a 1/4 inch zinco! I did this some
years ago in England with a karmann ghia script badge then ran off about 10 and got them all chromed,
Herbie
53 Bugs are not nearly enough
Threads: 51
Mood: Nihil curo de ista tua stulta superstitione.Utinam logica falsa tuam philos
posted on October 11th, 2004 at 04:21 AM |
Send it to me before you destroy the badge,
I do this sort of thing all the time, I would be happy to make a mould for you.
dont let silicone sealant set on the badge or it will be history.
62 Ragtop Herbie with a little extra oomph.
