| [ Total Views: 390 | Total Replies: 6 | Thread Id: 25761 ] |
Mr Bubble Head
Theme: UltimaBB Powder
| posted on July 9th, 2004 at 11:36 PM |
early type 3 rear brakes into porsche pattern
I've been looking into converting my rear brakes on my 57 bug to type 3 early (wide five) brakes. I have heard that the type 3 early rear drums will
have to have studs put into them which makes sence. I've been looking at the drums with the correct webbing inside ie not the swirl type but I'm
still confussed as there appears that the webbing is not wide enough inside the drum to drill and fit the studs into.
I wouldn't want to have these machined down so the studs can go in sqware as this could cause strength problems in the casting
Has anyone had this done or is there any related links?
nIck
recycle, restore, enjoy
seagull
Threads: 752
| posted on July 10th, 2004 at 12:09 AM |
did you try a search nick /
seagull
Threads: 752
| posted on July 10th, 2004 at 12:13 AM |
are the studs getting fitted ?
can you not use the drilled and taped holes ?
Mr Bubble Head
| posted on July 10th, 2004 at 05:09 PM |
type 3 rear brakes
I have done a search to no avail as most people retain the wide five stud pattern
The idea of studs is that the wheels I'm using are porsche rims and there better suited to that type of fitment I could drill a tap the drums but the
studs are a far safer way of going about it as they would not have the danger of threading or even pulling through the drum
nIck
Grey 57
A.k.a.: Dean
Old Grey Cruiser
Threads: 355
Mood: (OoVoO) (OVO).
| posted on July 10th, 2004 at 05:27 PM |
Why not use the later T3 drums?
seagull
Threads: 752
| posted on July 10th, 2004 at 07:25 PM |
I would get rid of the drums at this time , go the ford EA eb conversion ,this is one I have done on irs , the same for swinger seagull
[Edited on 10-7-2004 by seagull]
| Error |
seagull
Threads: 752
| posted on July 10th, 2004 at 07:26 PM |
backing plate set up
| Error |
DougD
Threads: 7
| posted on July 10th, 2004 at 08:58 PM |
G'day Seagull, You say that you did the conversion. I have an IRS rear with T3 drums on a Manx and am not real happy with it. Is your conversion
able to be engineer certified? I assume that as long as there are no welds it should be OK. It seems that having welds is a problem with the brakes.
How much would you be able to do the conversion for and what would it include or what would I have to get to do it to my rears on the buggy??
Cheers, Doug
Mr Bubble Head
| posted on July 13th, 2004 at 05:22 PM |
type 3 rear brakes
would drums off a thing aka 181 work on type3 early rear brakes?
