| [ Total Views: 1209 | Total Replies: 6 | Thread Id: 25806 ] |
Ross
Threads: 41
Mood: always smiling
posted on July 11th, 2004 at 05:20 PM |
Any tips on fitting 1600 to beetle and split
In the process of installing a 1600 into my beetle (and my
split), as i need to grind down the inner bell housing of the
gearbox i was wondering if any of you guys or girls know the
easiest way to do this without lifting it back in uncountable
times????
Any help would be great>>>>>>>Cheers Ross
fish
Threads: 32
Mood: just cruisin
| posted on July 11th, 2004 at 05:42 PM |
go to super cheap and buy a die grinder. does short work of it. do not use a grinder as the magnesium in the gearbox can ignite and whoosh, youv'e
lost your split or beetle. either that or just put it in and it will wear away the housing its'self over a couple of days. cheers, fish
Drink and drive your a bloody idiot!!! make it home you'r a legend !!!!
68AutoBug
| posted on July 11th, 2004 at 06:20 PM |
Yes, I read where a fellow in the US.. just used His starter motor to cut it out... just did the bolts up a bit at a time..
the ring gear makes short work of it...
My Son used an angle grinder...
Lee --
fish
Threads: 32
Mood: just cruisin
| posted on July 12th, 2004 at 05:57 AM |
just be carefull as the grinding stuff is verry fine and can ignite with a white flsh. try throwing some on a fire and see. whoosh it's gone.
Ross
Threads: 41
| posted on July 12th, 2004 at 06:35 PM |
thanx fellow dubbers... the idea of letting the flywheel do the work sits well with me>>>>>>>>>>>>>Cheers
Oh... would you suggest turning it over by hand or just starting the engine up???????
phatrat
A.k.a.: steve
REALLY!
Mood: Buggin Out
| posted on July 12th, 2004 at 08:40 PM |
posted by Ross
u have to be joking!
fish
Threads: 32
Mood: just cruisin
| posted on July 13th, 2004 at 04:31 AM |
just kick it over with the starter. works a treat.
Ross
Threads: 41
| posted on July 13th, 2004 at 07:02 PM |
Thanx fish
karmannghia60
Karmann Ghia Sucker
Threads: 388
| posted on July 23rd, 2004 at 11:02 AM |
Hey Ross, why don't you just use a 6v flywheel instead of messing around? Its not just clearing the bellhousing, the start gear is different because
of teh different number of teeth on the flywheel
[Edited on 23-7-2004 by karmannghia60]
