| [ Total Views: 534 | Total Replies: 13 | Thread Id: 25863 ] |
phantom
Threads: 196
Mood: Where does this wire go?
posted on July 12th, 2004 at 09:29 PM |
Pushbutton Ignition
Can anyone tell me why some people put in pushbutton ignition to their cars?
My 69 bug has pushbutton ignition, as in, turn the key to get ignition lights, then push a button to start the car. The previous owner said that he
had ignition hassles and they 'fixed' it with this button.
To me, if the key turns, it should be OK to start the car. Or, you replace the key and lock. I dunno. Can anyone enlighten me? Anyone else got
this in their VW?
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on July 12th, 2004 at 09:31 PM |
the ignition switch snuffs it for whatever reason and rather than replacing it they go the short term fix and wire in a push button and it become
permanent
pod
A.k.a.: paul mrvw061
Mood: could be better
| posted on July 12th, 2004 at 09:38 PM |
yeah as barls said, temp fix wich becomes permanent .time for new ignition if you want to fix it properly
barls
Threads: 296
| posted on July 12th, 2004 at 09:40 PM |
ill put it this way half of the kombis my old man services have push button or toggles so you are not alone on this one
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
| posted on July 12th, 2004 at 09:41 PM |
i got a push button set up in the buggy. more the fact some people stick gun in the ignition. and rubbish in your footwell.
Simply Cruzin'...
68AutoBug
| posted on July 13th, 2004 at 01:31 AM |
Well it was good enough for the early beetles to have a push button....
they are more reliable than a 35 year old key switch with dirty contacts...
Usually a relay will fix the problem with a dodgey ignition switch, as a relay takes very little current whereas the ignition system takes a few amps
to start the engine...
also a push button switch is cheaper and easier to find than a new key switch....
much better than an ignition switch out of another car taped to the side of the steering column.... YUK...
Lee -- 68AutoBug --
68AutoBug
| posted on July 13th, 2004 at 01:35 AM |
Also, some people think its cool to start the engine with a key switch....
same as Formula 1 racing cars..... Super V8 touring cars ..
Rally cars etc...
all start with a push button...
they know the button IS going to work when its pressed....
Lee --
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on July 13th, 2004 at 09:20 AM |
I installed a push button in my previous kombi because I was quoted too much (at the time) for a new ignition switch. As already suggested, it was
meant to be temporary until I could afford one, but became permanent.
I took the power supply to the push-button from the ignition 'ON' terminal at the original switch, and run the other contact from the push-button
into the starter wire, meaning that the key was still needed to get power to the starter anyway.
Honestly, there is no disadvantage to having a push-button, other than the fact that it is not standard. If anything, it makes an interesting novelty.
:thumb
Kruizin Kol
kombikim
A.k.a.: Kim
disfunctionally capable
Threads: 84
Mood: always bleary
| posted on July 13th, 2004 at 09:28 AM |
ANOTHER REASON many kombi s have a push button, is the stupid "turn ignition right off to hit starter again" ignition switch, which can be very
awkward when the vehicle stalls in traffic, our first kombi had both keystart & button, I will be putting that setup in our current kombi when I
have time
Please, I need drivers side window regulator (winder mechanism) for my '54
vw54
| posted on July 13th, 2004 at 09:39 AM |
Most people dont realise taht you can purchase the origional ignition key module the plastic bit CHEAPER tahn you can buy a push button for
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on July 13th, 2004 at 09:53 AM |
I need a new ignition switch for my 1978 Kombi. Any ideas where I can get one new and what it will cost?
Mine currently has a dodgy push button to start but you still need to use the key to unlock the steering column and I'd like to fix the ignition
switch.
bus356
Threads: 50
| posted on July 13th, 2004 at 10:56 AM |
My 77 kombi came with push button, went unreal, never had a problem ever...
Da Wiz
Threads: 27
Mood: ¯`·.¸¸.·´¯`·.¸¸
| posted on July 13th, 2004 at 11:25 AM |
is there any wiring diagrams availabe to DIY ... my switch on the kombi packed it in last week, and i feel getting a whole new barrel is going to be
expensive, plus will require another set of keys ... any tips
kombikim
A.k.a.: Kim
Threads: 84
Mood: always bleary
| posted on July 13th, 2004 at 11:29 AM |
the actual switch is seperate (able ) from the key & barrel , you only need the switch itself
barls
Threads: 296
| posted on July 13th, 2004 at 11:34 AM |
there are some in the gregorys manual or there is a very simple on thats based on a 64 bug in the vw bible( idoits manual) i dont have a copy for the
kombi. but i think you can get the new switch from micks in Qld or classic in sydney
68AutoBug
| posted on July 13th, 2004 at 02:27 PM |
see http://www.vintagebus.com/
for all VW wiring diagrams...
USA wiring diagrams are different to the rest of the world VWs...
