| [ Total Views: 1276 | Total Replies: 18 | Thread Id: 26241 ] |
EgeWorks
Threads: 52
Mood: No worries
| posted on July 21st, 2004 at 11:42 AM |
What do people use as a plug spanner?
Like the subject says, what do you guys and girls use to undo your spark plugs. My ratchet gets caught on just about everything. I end up using a
universal attachment to it but it still is pretty awkward. I suppose there is some special VW tool that I don't have...
aggri1
A.k.a.: Aurel Griesser
Threads: 35
Mood: ska'd for life
| posted on July 21st, 2004 at 11:52 AM |
I managed to use a ratchet. Needed a small extension for the deep plugs (2 and 4 I think). I've got an 1800 kombi, though, but still had to do some
fiddling to get stuff in place.
VolksFolks
A.k.a.: Pandy
Threads: 350
Mood: Proud DSK Contributor
| posted on July 21st, 2004 at 12:09 PM |
I often find it esier to just remove some tinware, depens what you are working on though..
Andy
check out http://www.lowlight.com.au for low lights only..
EgeWorks
Threads: 52
Mood: No worries
| posted on July 21st, 2004 at 12:25 PM |
I'm working on a 1600tp beetle. I can do it with the ratchet but it takes a fair amount of time and a lot of swearing I was thinking of getting something welded up specially...
Bizarre
| posted on July 21st, 2004 at 12:31 PM |
It is handy if you have 2 short extensions - gives it a bit of bend.
If you are a butcher like me - cut a couple of holes in the inner guard and use a 10"and 2"extension and get to it through the side wall
Another thing that REALLY helps is to drive the hinge pins out of the engine lid and replace then with either R clips or old dip sticks.
Then you can take the lid off and work down from the top. This helps a real lot.
Makes up for the inconvienience of loosing the spring
lobus
Threads: 93
| posted on July 21st, 2004 at 12:59 PM |
I use Fred the mechanic.
I've never crossed a thread or skinned a knuckle yet.
BiX
Threads: 154
| posted on July 21st, 2004 at 01:02 PM |
with my dual carbs I cut a hole in each inner guard. But I used to find on the old 1600tp, use a pices of garden hose to get them started and in to
finger tight, then try using a 1/4 ich socket and play around with extensions/joints etc, until you get the combo that works!!!
Go hard or go home!!!!
Gracey
Threads: 17
Mood: Itchy
| posted on July 21st, 2004 at 01:14 PM |
Swivel head 3/8" drive ratchet with a short wobble type extension. The first time I did sparkplugs on a beetle took me about 1.5 hours and I
couldn't believe how hard it was, luckily it gets heaps easier with practice.
Bugged Again
Threads: 46
Mood: beetle-less
| posted on July 21st, 2004 at 01:30 PM |
Just a ratchet with extension
piece of piss, can't see what the hassle is
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on July 21st, 2004 at 02:27 PM |
Same, just a 3/8 Ratchet with an extension and a normal type plug spanner.
It does help though if you make sure the rubber is inside the socket to hold onto the plug so it doesn't fall down inside the engine tinware. Mine is
long gone, so I use a piece of fuel hose with the little threaded bit off an old spark plug. Loosen the plug with a ratchet, but before it completely
unthreads, screw the hose on to lift the plug out.
Kruizin Kol
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on July 21st, 2004 at 02:38 PM |
I use a Snap On magnetic plug socket (3/8) and a flexible extension for the front plugs and a 2 inch extension for the rears. Never found it
difficult???
tssnq.com.au
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on July 21st, 2004 at 04:25 PM |
i prefer a little stubby ratchet with a 3 inch wobbly extension. its just the right size to fit in palm of the hand. but then again ive spent most of
my life workiing on cars.
EgeWorks
Threads: 52
Mood: No worries
| posted on July 21st, 2004 at 05:26 PM |
Well I just changed my plugs using a 3/8th ratchet with a wobby extension for the back cylinders. It was sweet! Pity it is my brother's ratchet... I
may have to "borrow" it for a while.
Thanks for all your good advice people
Madeline
Threads: 1
| posted on July 21st, 2004 at 09:52 PM |
Jack the engine up on one side under the heater box (with a block of wood between jack & heater box).This will make it a bit easier for you.
DubCrazy
A.k.a.: steff
| posted on July 21st, 2004 at 09:59 PM |
I just use a plug spanner you get free when you buy a new motorcross bike, rightangled plug spanner. it works perfect and i have a few so i never have
to hunt for it :thumb
steff..................... |
1303Steve
| posted on July 21st, 2004 at 10:17 PM |
Hazet make a special plug socket for VWs, it makes life much easier. The cheap racthet and socket sets that have a swiveling handle work well the
beetle engine bay.
1302Steve
ph billet
Threads: 46
| posted on July 21st, 2004 at 10:30 PM |
a tube spanner with a ring spanner on the other end hex in lets you turn a little at a time in a confined space.
68AutoBug
| posted on July 21st, 2004 at 10:59 PM |
I use a double ended VW tube spanner that takes the fan belt off, takes the wheel studs off and takes the spark plugs out..... Very handy, I think
it came with a type 3 variant, I had many years ago... was supplied with the car...
All the early beetles used to have one in their tool kit..
I think a 1302S I also had years ago had one of these tools...
Its written in some VW manuals that You should use anti seize on the threads of spark plugs in VW engines due to the difference in heat expansion
between the steel spark plug and the alloy case... I always do...
Lee..
ph billet
Threads: 46
| posted on July 22nd, 2004 at 07:59 PM |
good tip Lee could save a lot of tears later.
oval TOFU
Bitte, ein Bit!
Threads: 234
Mood: :booM
| posted on July 22nd, 2004 at 11:54 PM |
I just use a normal spark plug removeing socket attached to a uni-joint extensionn then onto my ratchet - 1/4", 1/2".. it dont make a difference
with me... takes me no time to take out all my plugs - and I keep all the skin on my knuckles
~air fooled~
Threads: 96
Mood: so far..away..
| posted on July 23rd, 2004 at 01:45 PM |
i just grab one of the indian kids from the sweat shop next door to come and poke his little fingers inside and get em' undone. he does it for free,
beats sewing soccer balls.........
