| [ Total Views: 406 | Total Replies: 7 | Thread Id: 26276 ] |
bigbruvabob
Threads: 43
Mood: grouse
| posted on July 21st, 2004 at 10:00 PM |
a question about the coil
hi guys am going to change the coil over on andreas roadster to a gt 40 that i have but my problem is the coil on the car is not marked with +ve or
-ve. Can someone please confirm that power from ignition goes to +ve and -ve goes to distributor. Cheers david
Madeline
Threads: 1
| posted on July 21st, 2004 at 10:10 PM |
Just buy a new one that IS marked.
karmannghia60
Karmann Ghia Sucker
Threads: 388
| posted on July 21st, 2004 at 10:13 PM |
Hey Dave, yes -ve to distibutor and +ve to loom
68AutoBug
| posted on July 21st, 2004 at 11:03 PM |
A coil will work either way round....
although Not as well, when its around the wrong way...
and it can cause problems...
Positive + Power to the coil +
Negative - to the points & condenser.
toplessbug
Threads: 128
Mood: waiting for my lotto win
| posted on July 22nd, 2004 at 09:24 PM |
make shure its a gt40 not a gt40R as the R model is designed to work with a ballast resistor and will quickly destroy your points if you use it |
bigbruvabob
Threads: 43
Mood: grouse
| posted on July 24th, 2004 at 11:00 PM |
ah ha!
yes lee thank you i believe that this is the problem with the coil on there at the moment.As when i hook up my dwell meter to what should be +ve it
nothing happens but when i hook it up to what should be -ve i get reading. this is the reason i want to change the coil over as it is getting me
confused.
bigbruvabob
Threads: 43
Mood: grouse
| posted on July 24th, 2004 at 11:01 PM |
ah ha!
confused.
bigbruvabob
Threads: 43
Mood: grouse
ah ha!
confused.
bigbruvabob
Threads: 43
Mood: grouse
| posted on July 24th, 2004 at 11:05 PM |
ah ha!
confused.
*did*
A.k.a.: Steve
Threads: 0
Mood: happy
| posted on July 26th, 2004 at 10:18 AM |
has anyone tried the gt40t (transistor) coil? according to the packaging these are better at operating through high heat and vibrations. i'm thinking
i might try one. |
