[ Total Views: 1160 | Total Replies: 3 | Thread Id: 26622 ]
Author: Subject: A lesson in acceleration
Memberreub
VWRX is gone...
thumbup.gif posted on July 29th, 2004 at 11:35 AM
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1½ gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an average of over 4G's. In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed reading this sentence.
* Top Fuel Engines turn approximately 540 RPM's from light to light! This one confused Stan, but stop & ponder the fact that the engine is only used for apx 4 to 5 seconds.
* Including the burnout the engine must only survive 900 revolutions under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second. The current Top Fuel dragster elapsed time record is 4.441 seconds for the quarter mile 10/05/03, Tony Shumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of the run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the RC211V hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph (293 ft/sec). The tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your wrist cranked hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you
He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
That, folks, is acceleration.
Reub
MemberCraig Torrens
A.k.a.: Craig Torrens
Threads: 347
posted on July 29th, 2004 at 03:21 PM
Maybe it confused him because it is wrong !!!
RPM means "Revolutions per MINUTE".........................the motor actually "turned" 540 times in 4 to 5 seconds.............meaning the motor revs at 8100 RPM.
Memberreub
VWRX is gone...
posted on July 29th, 2004 at 04:41 PM
True......but still an interesting read from an email I received.
Reub
MemberCraig Torrens
Threads: 347
posted on July 29th, 2004 at 10:00 PM
Good read !..........if only we could produce the same for a VW!!
MemberBeetle426
Threads: 17
posted on August 15th, 2004 at 10:23 AM
Yeah baby! Hemi's are the King Kong!!!
Membershiftyvw
Threads: 44
posted on August 17th, 2004 at 08:40 PM
Actually the 9500rpm is wrong. The cars dont rev much over 8200, at least the ones I know of, but they sustain that for the entire race
[ Queries: 40 ] [ PHP: 10.8% - SQL: 89.2% ]
