| [ Total Views: 402 | Total Replies: 0 | Thread Id: 26957 ] |
dodge
Threads: 82
Mood: dubbing
| posted on August 6th, 2004 at 10:36 PM |
relay box
while i'm askin questions........
what does it mean when your relay box (a little blue box directly behind my fuse box) is making noises? almost like the indicator is on permanently
(the circuit is going on and off)
is this a problem? or something normal? |
1303Steve
| posted on August 6th, 2004 at 11:03 PM |
Hi Dodge
Are your blinker working? I blew 2 bulbs on one side of my bug and every time I used the blinkers the relay buzzed, when Ive blown 1 bulb the
blinkers just flashed fast.
1302Steve
68AutoBug
| posted on August 6th, 2004 at 11:58 PM |
Relays shouldn't click unless they are switching on & off like blinker relays... but they shouldn't buzz...
that usually means the relay has had it... and its switching on & off all the time ?? or the points [contacts] inside have stuck together...[welded together] and need replacing...
a relay should be either On or Off...
they are just an electric switch....
I use them to save all that current going thru My old original VW switches...
| Error |
