| [ Total Views: 1218 | Total Replies: 14 | Thread Id: 27125 ] |
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 05:57 PM |
how to tell....about webbers
ok i was told before to make sure they are dual "IDA"
how do i know if they are ?
also how much are they worth ruffly ??
i have one of them in my lap right now so i should be able to see what ever gets mentioned
thanks guys luke
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 06:29 PM |
even a link would help too, i should of mentioned that up there ^^^^^^
oh yeh bump
wibble
A.k.a.: Warren Way
Freakinbuggied
Threads: 41
Mood: #$!& the goverment
| posted on August 10th, 2004 at 07:23 PM |
On the bottom of the casting (where the carb bolts down) it should have the size and idf/ida/dcnf etc, there are a lot of types, if you can post a pic
we can identify it..
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 07:24 PM |
will do it'll be up in 5 mins
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 07:42 PM |
while posating these i found on the opposite side just undr where it appear the fuel in line is it sez : 40 idf 18 0L. is that the info that you
were talkin about ?
johny rotten
| posted on August 10th, 2004 at 07:47 PM |
Early model IDF carbs
johny rotten
| posted on August 10th, 2004 at 07:48 PM |
roughly 600 give or take some.
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 07:49 PM |
would these suit my 2ltr kombi or give it any noticeable power gain ?
johny rotten
| posted on August 10th, 2004 at 07:50 PM |
yes they will suit and give you some extra power
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 07:58 PM |
so whats the 40 idf 18 0L stand for ??
wibble
A.k.a.: Warren Way
Freakinbuggied
Threads: 41
| posted on August 10th, 2004 at 08:14 PM |
not sure about the 180L 40 is the size (40mm) the chokes have also been blanked off on that one (wont hurt them)
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 08:19 PM |
thanks guys :beer any idea how much a set is worth ??
the guy hasnt said a price yet so i just want to know a ball park figure on them so i know what ruffly to expect.
thaks again. luke
pyr0
flame-on
Threads: 123
| posted on August 10th, 2004 at 10:45 PM |
one last bump
thanks for all the help anyways guys, always good to learn from others
cheers :beer luke
Oasis
Going alone...
Threads: 77
Mood: Deep
| posted on August 10th, 2004 at 10:59 PM |
For what it's worth, my webers gave me 1 hp more than my Kadrons, but gave me most of that power over a greater rev range, rather than the Kadrons
having (almost) the same peak power but only for a small rev range. It made the car feel faster and more responsive. The down side is I'm at the
moment using a RIDICULOUS amount of fuel. I have to sort that out. They cost me around $700, but were newer than these.
seagull
Threads: 752
| posted on August 11th, 2004 at 12:57 AM |
I paid $800.00 for mine , they were all serviced * glass blast* c/w new kits, they had new K&N air cleaners fitted .
I would say a fare price for what you have there would be $400.00 > $450.00
pyr0
flame-on
Threads: 123
| posted on August 11th, 2004 at 07:54 AM |
thanks for that one guys, as for the fuel consumption oasis my bus guzzels it now and no one knows why so im hoping that we might be able to sort the
webbers out a little better
AdrianH
Threads: 20
Mood: rebuilding again
| posted on August 12th, 2004 at 06:31 PM |
Check the throttle shafts, old carbs wear between the body and the throttle shaft, if you have an airleak there they will constantly fall out of tune.
To get them rebushed can cost more than the carbs are worth... If you have any lateral movement around there I would give it a miss.
The numbers after 40idf relate to themodel of idf. They had different circuits and emulsion tube set ups dependant on what they were originally on.
Some will run better than others on a VW .
