[ Total Views: 483 | Total Replies: 14 | Thread Id: 27234 ]
Author: Subject: Metal question? Dave? Pete?
MemberAdam_C
Threads: 164
Mood: could be lower
posted on August 12th, 2004 at 04:10 PM
can anyone here tell mewhere to find, or spply me with some almuminium tube 50mm inside diameter? anyone?
adz
Adam
Adzslick@iprimus.com.au
MemberBiX
Threads: 154
posted on August 12th, 2004 at 04:30 PM
just try the alum shoops, sellers. We have a few places just sell aluminum sheet, pipe, around brissy.
a quick yellow pages search http://www.yellowpages.com.au/search/performSearch.do?headingCode=14877&l...
Go hard or go home!!!!
posted on August 12th, 2004 at 05:48 PM
got to the alloy placeat rockdale but there must be one closer to you.
MemberAdam_C
Threads: 164
posted on August 12th, 2004 at 05:49 PM
smithfeild lol closest in the book...... the local place doesnt stock AL tube ... guna do some more ringing tomorrow and possibly go for a drive hehe
Adam
posted on August 12th, 2004 at 05:52 PM
What do you want alloy tube for ???? the inlet mainfolds ???
MemberAdam_C
Threads: 164
posted on August 12th, 2004 at 05:58 PM
Nah, for the velocity stacks i am going to fab up, will just make the inlet from steel, not guna waste time and $$ with alloy for manifolds, i cant weld alloy..... meanwhile, would you be interested in a set of stacks, once i work otu the correct length and such ill have HEAPS of tube left over.... i thnik ill have to buy it in 3m lengths ..... but will ring around to some shops tomorrow i have the day off.....
Adam
Memberph billet
Threads: 46
posted on August 12th, 2004 at 10:08 PM
you can try metaland I think there is a branch at Ingelburn or O'Brians aluminium at Smithfield or the hardware store that sells hardware minto hardware if you are after a small amount less them 2 feet (2inch OD and 1/16 th wall thickness) then I have a bit here you can have for free you just have to come and get it.
MemberAdam_C
Threads: 164
posted on August 12th, 2004 at 10:12 PM
u have u2u
Adam
Member~air fooled~
Threads: 96
Mood: so far..away..
posted on August 13th, 2004 at 11:50 AM
knock some accessories off of the local ricers car and make your own matey!!
Memberspeedster356
A.k.a.: Peter Mcleod
Plastic not Classic Racing
Threads: 256
posted on August 13th, 2004 at 12:44 PM
Tube is always measured by the outside diameter, so 50mm alloy tube will be smaller on the ID than you wanted. I have plenty of 50mm tube if you want some, it's 1.6mm wall thickness I think.
MemberAdam_C
Threads: 164
posted on August 13th, 2004 at 01:07 PM
just picked sum up from Pete (Ph billet) thanks mate, and tell your wife i didnt meen to be rude hehe i didnt want to hold her up she was on her way out :P
thanks for the offer pete
adz
Adam
Memberno slow 63
Threads: 16
Mood: Mentally ill
posted on August 13th, 2004 at 01:35 PM
I can get you 50mm I.D tube. You'll have to come to Melbourne to pick it up though.
MemberAdam_C
Threads: 164
posted on August 13th, 2004 at 03:16 PM
lol got soem tube, and it worked great.... might get larger diameter tube and make another one, if i can get it, or just make a sleeve to mount it on the carb...... epoxied together.... ah the possibilities, thanks guys, and Ph Billet..... thanks heaps man but if you find the larger tube at work id be keen to grab it aswell....
thanks
adz
Adam
Memberph billet
Threads: 46
posted on August 13th, 2004 at 03:30 PM
sorry I looked today but nothing .
MemberAdam_C
Threads: 164
posted on August 13th, 2004 at 11:23 PM
no probs, thanks anyways man, that shit after i annealed it .... was sweet hammered it out into the flange and vwala velocity stack
Adam
MemberPaul Aslanides
Mood: Vive Le Kombi !
posted on August 14th, 2004 at 11:00 PM
How did you anneal it ? Can you do small sections with a gas torch? Or use the wife's gas oven ? About what temperature, celcius ? Was it 6061 or another grade ? Thanks.
MemberAdam_C
Threads: 164
posted on August 15th, 2004 at 07:04 PM
youll have to ask the above ^ people what grade it is, i simply heated it untill it the flame was red when it JUST passed over the peices end, then let it slowly cool, i wasnt surte on the grade of alloy and i didnt know it of was a heat treatable alloy so i didnt quench it incase it made it brittle, i worked it while still warm wearin thick leather gloves......used a propane torch, but if i was to anneal with oxy acet then the process is a little different.
Take an acetelene flame and pass it over the peice to build up a decent layer of soot, then take a normal blue flame and burn off the soot, becareful, aluminium melts at about 1200C and the oxy burns at 800C (but that could be farenheit i cant remember) hope that helps.......
ad for the wifes oven..... im 17 .... id have to use mums, and that is more dangerous hehe
Adam
