[ Total Views: 646 | Total Replies: 15 | Thread Id: 27471 ]
Author: Subject: Fitting tilt steering to the Desert Splitty.
MemberDesert Bug
Threads: 72
Mood: NOW VERY HOT AND HUMID!!!
posted on August 16th, 2004 at 11:20 PM
G'day,
If you are over 6' tall you no my problem trying to get comfortable driving the beloved Splitty, knees up in ya armpits head bent down to look out the top of the windsceen, etc. The only half comfy way is leaning forward with elbows on the steering wheel and hands at 5 past 11 at the top of the wheel.
Well seeing how I've done quite a few mechanical mods to the Desert Splitty, I've decided to fit a tilt steering column. I've already fitted Camira buckets which sit lower and are fitted 100mm further towards the rear which helps to see thru the sreen and straighten the legs a bit but now the steering wheel is too far away which makes my neck and shoulders ache, so the solution is Tilt the Wheel towards me for a more comfy position.
I borrowed the best set of ramps I've ever used, they're 400mm high and you can sit underneath and work comfortably.
Cheers, Ian.
MemberDesert Bug
Threads: 72
posted on August 16th, 2004 at 11:22 PM
This pic shows outer column bolted in and tilted down.
MemberDesert Bug
Threads: 72
posted on August 16th, 2004 at 11:24 PM
Column tilted up for extra room getting in or out.
MemberDesert Bug
Threads: 72
posted on August 16th, 2004 at 11:25 PM
Pic of cut down column with new end fitted ready for welding in place.
Memberfrog
Threads: 49
Mood: is what the cow did yesterday.
posted on August 16th, 2004 at 11:31 PM
Yeah,good one
as I find splitcabs a bit small too,and lower seats are the go like sitting on an old barndoor bench seat feels much better than the later model ones,makes the cab feel bigger.
"-Hannovermetalmadness-"(Infectious desease with no known cure).
Memberseagull
Threads: 752
posted on August 16th, 2004 at 11:45 PM
and next the gear stick extension !
MemberDesert Bug
Threads: 72
posted on August 17th, 2004 at 08:58 AM
Hi Seagull.
I hadn't thought of that, and I've got one of those screw on ones down in Vic, I'll get Rhett to send it up.
Cheers, Ian.
MemberMikeM
Buggy Head
Threads: 71
Mood: :duh
posted on August 17th, 2004 at 09:23 AM
That's really cool!
What is the Tilt Column out of? Or did you fabricate it?
[Edited on 17-8-2004 by MikeM]
Memberdavid
Threads: 157
Mood: amicable
posted on August 17th, 2004 at 10:24 AM
i like the foot stool ian
your a bit tall and i guess your wife is petite, love the mods keep up the good work
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on August 17th, 2004 at 10:31 AM
Awesome job Ian. I've been thinking of doing the same thing to gain some room between myself and the steering wheel in the '75, but I can't work out where it would tilt to... seems to me that if I tilted the wheel forward, the top (front) would hit the dashboard.
I suppose the answer to my problem is to fit a tilt column with a smaller steering wheel, but then I'd probably want power steering as well... :duh
Kruizin Kol
MemberDesert Bug
Threads: 72
posted on August 17th, 2004 at 02:06 PM
The column tilt section is out of a Mitsubishi L300 forward control 4x4 bus, with a slight mod to the mounting bracket it bolted straight up to the Splitty mounting bolts using 2 original holes in the M/bishi mounting plate, the lower section of tube is from a Lancruiser column which ,cut to length fits nicely inside the M/bishi upper tube. Inside this tube is 3/4 of the original Splitty column with the splined end of the M/bishi fitted and welded into the top of it. The top part of the column is being modified to EL Falcon to fit the Falcon wheel, which has the centre offset about 25mm, so at the top of the wheel where you need leverage it is only 15 mm smaller radius and at the bottom it's about 40 smaller radius. The wheel is also nice and thick to grip. Once it is all fitted I'll make a vinyl cover for the tilt section to hide the mechanism and make it look tidy. I'll be using the Splitty indicator stalk and locating the horn button to the dash.
Cheers, Ian.
MemberDesert Bug
Threads: 72
posted on August 19th, 2004 at 08:48 PM
G'day,
I haven't had a chance to do any work on the column during the week due to a bout of the Flue, so hopefully will be able to finish it this weekend.
Cheers, Ian.
MemberDesert Bug
Threads: 72
posted on September 7th, 2004 at 01:37 AM
G'day,
Well the tilt steering is in and working great and have done over 1000ks since finishing it with no sore neck problems. The wheel is in a very comfortable position and is very easy to use.
Will post a pic when I remember to take one in daylight.
Cheers, Ian.
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
posted on September 7th, 2004 at 12:00 PM
cant wait to see the mod finished is a great idea for us tall fellas driving buses!
ian i think you are gonna have to start manufacturing all these wonderful ideas!
rhys
MemberDesert Bug
Threads: 72
posted on September 8th, 2004 at 08:08 PM
Hey Rhys,
Mate I haven't got time to scratch myself, I'm having that much fun thinking up new ideas and mods for the Splitty, and having heaps of dead cars to get bits from makes it more fun. I enjoy passing on all my ideas so you folk can have a crack at doing them for yourselves. Next on the list is rear discs.
Cheers, Ian.
MemberDesert Bug
Threads: 72
posted on September 9th, 2004 at 12:35 AM
G'day,
couple of pics of completed tilt steering, still need to paint.
Cheers, Ian.
MemberDesert Bug
Threads: 72
posted on September 9th, 2004 at 12:39 AM
2...XF Falcon wheel is very comfortable to use. Need to fit horn button on dash. Will make vinyl cover to hide mechanism.
MemberHotRodMatt
If it's old or rare - cut it!
Threads: 361
posted on September 9th, 2004 at 09:38 AM
Well done. I like!
[ Queries: 40 ] [ PHP: 3.6% - SQL: 96.4% ]
