| [ Total Views: 479 | Total Replies: 4 | Thread Id: 27479 ] |
Shadbug
Threads: 7
posted on August 17th, 2004 at 10:41 AM |
speedometer problem
Hi,
I was driving home in my 71 beetle last night and the speedometer started making a racket! I pulled over and disconnected the cable so I could drive
home in peace. Can anyone suggest what could be the cause of the problem?
Oasis
Going alone...
Threads: 77
Mood: Deep
| posted on August 17th, 2004 at 10:43 AM |
It happened to me a month ago. It was just the cable and went when I replaced it. Cheap fix.
PurpleT3
Threads: 55
Mood: knackered
| posted on August 17th, 2004 at 10:49 AM |
The only way to tell for sure is to open it up and have a look. If you aren't confident to do this, you can buy a second hand one from a VW mechanic
or wrecker fairly cheap (under $50)
Oasis
Going alone...
Threads: 77
Mood: Deep
| posted on August 17th, 2004 at 11:13 AM |
Try the cable first. It'll only cost you 10 bucks... Then if it's not that change the speedo, or pull it apart.
[Edited on 17-8-2004 by Oasis]
Shadbug
Threads: 7
| posted on August 18th, 2004 at 12:53 PM |
Thankyou
Thanks for your replies that is really helpful, I will pop my old MPH speedo back in to see whether the noise remains, if so I will replace the cable.
Bugged Again
Threads: 46
Mood: beetle-less
| posted on August 18th, 2004 at 12:56 PM |
Mine did that in cold weather & finally snapped a couple of weeks ago.
Put replacement in and now works fine, took all of 5 mins.
$20 from Micks Motors
68AutoBug
| posted on August 18th, 2004 at 02:03 PM |
The cable usually breaks strand by strand... so the speedo would have started playing up as more & more strands broke...
I always put a few drops of oil into the top of the speedo cable to lubricate the inner cable....
