| [ Total Views: 467 | Total Replies: 8 | Thread Id: 27524 ] |
matara
Threads: 255
Mood: 356'd
| posted on August 18th, 2004 at 11:23 AM |
Starter Motor Removal
Went to start the splitty this morning, and I think the starter motor or solenoid has given up the ghost! Battery seems fine, and jumping it didnt
help.
I have a spare 12v starter, but can anyone tell me how difficult is it to remove the starter on a split (or beetle) with the motor intact? I would
think that it would be tricky disconnecting everything and getting a socket to the bolt, but can it be done?
HotRodMatt
If it's old or rare - cut it!
Threads: 361
| posted on August 18th, 2004 at 11:25 AM |
Takes a bit of stretching but it can be done!
VWFREAK
A.k.a.: Peter / Bones
VWFREAK
Threads: 264
Mood: FREAKY
| posted on August 18th, 2004 at 11:41 AM |
Easy job, just a couple of bolts and wires.
vw54
| posted on August 18th, 2004 at 12:02 PM |
disconnect the battery first
Undo the 17mm nut inside the engine compartment, hopefully you have a starter that locks the bolt onto it using the head
then undo the 13mm nut on the battery cable at back of starter
then remove the push on ignition wire on soloide
lastly undo the lower 17mm nut and the starter will pull out.
Easy while your laying on yr back especially in a Kombi with extra ground clearance.
1303Steve
| posted on August 18th, 2004 at 12:24 PM |
Hi Steve
Make sure the smaller wire on the solenoid is connected, it just pushes on and often falls off. Check this 1st before pulling it out.
1302Steve
Bugged Again
Threads: 46
Mood: beetle-less
| posted on August 18th, 2004 at 01:00 PM |
bit of gymnastics required and the engine bolt can be a bugger to get out.
Obviously do it when the motor is cold
vw54
| posted on August 18th, 2004 at 05:03 PM |
Yep first thing to check but you have to get under the car to do so
Kafer Lover
Threads: 71
Mood: Low
| posted on August 18th, 2004 at 09:01 PM |
If jump starting didn't help, wouldn't that mean that the starter isn't the problem?
John Muirs book how to keep your vw alive has a very good description of how to test if its the solenoid or starter (or ignition switch) that is at
fault, without taking it out of the car, if you can get hold of a copy.
matara
Threads: 255
Mood: 356'd
| posted on August 18th, 2004 at 09:53 PM |
thanks all,
The starter was a bit lazy starting it the day before and I thought it may be a duff battery!
When the rain stops I will crawl under and have a go.
Hey Steve1302 should you be Steve1303 now?
1303Steve
| posted on August 18th, 2004 at 10:18 PM |
Hi Steve
When you get under the car take a test light with you, get someone to try to start the car, making sure its out of gear and test for power at the
little push on terminal and battery power at the bolt on terminal. Use the test light to make sure its fully bright when cranking at the bolt on
terminal and also you can make sure your getting a good earth from the chassis to the tranny.
I will have to have a word to a forum guru about changing my user name.
1302or3Steve
Che Castro
ankle straps
Threads: 79
Mood: (( }:-{D]
| posted on August 18th, 2004 at 11:12 PM |
watch out when ur under the car that the starter doesnt fall on you! Its pretty darn heavy!
Jon
