| [ Total Views: 565 | Total Replies: 27 | Thread Id: 27575 ] |
Midlife crisis
Mood: Wornout and Toxic
posted on August 19th, 2004 at 04:21 PM |
Bosch type 3 Injection HELP!!
Hi I have a type 3 with FI.
I just transferred the engine and Auto into my car.
and I am having a few troubles. The car is very hard on fuel 40 L to travell 120 miles with my old wornout engine with carby's I git aound 300 mile
for 40L.
The idle is up and down, will idle smooth then it wll get rough and stall.
Drive down the road a bit it idles again then rough and stops.
It will restart with no trouble.
When you rev the engine it blows black smoke
I have checked the points, timing, no leaks anywhere front or back ,no leaks at the injectors. I cannot find any pipes off.
When we changed it into my car we did not take anything off the engine all the FI was left on . we put new fuel lines everywhere.
Does anyone have any Ideas because unless I can sort this out I we have to put carbys on it and throw the FI over my left shoulder
thanks
Marc
PurpleT3
Threads: 55
Mood: knackered
| posted on August 19th, 2004 at 04:58 PM |
300mile (482km) for 40l is about 28MPG, which sounds exceptionally good for carbs. I think the FI set up is supposed to get around 26MPG, but I'll
have to check.
Do you know whether the motor worked before you installed it in your car?
I would suggest you post your question here as well.
http://vwtype3.org/listarchive/threads.html
These guys have alot more functioning FI T3's than we do over here, and will be able to make many suggestions. I am going to tackle installing FI on
my fasty shortly, so I'm interested in your progress.
Midlife crisis
| posted on August 19th, 2004 at 05:26 PM |
Yes the car was running before we took the engine out butwe only went around the block. I will try that site
thanks
marc
PurpleT3
Threads: 55
Mood: knackered
| posted on August 19th, 2004 at 05:33 PM |
Do you have a Bentley manual or Muir's idiots guide? Both these books outline troubleshooting procedures to allow you to pin point the problem.
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on August 19th, 2004 at 05:54 PM |
Did you get all the earth wires bolted down, obviously it is going real rich when it chugs out the black smoke, what about the cylinder head temp
sensor? Is it screwed into the head? If not the computer will stay rich...
Check all the wiring conections again.
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Midlife crisis
| posted on August 19th, 2004 at 06:08 PM |
Thanks Graham I have checked all the earths and cleaned them. The sender is in the head we made a point of not undoing anything that we did not have
to to get the engine of of the other car. Tomorrow I will check the fuel reg to see if the diaphram is ok.
thanks guys for ideas willkeep you informed
Marc
Midlife crisis
| posted on August 19th, 2004 at 06:21 PM |
Just went and check the uel pump regulator and it seems ok.
the wire to the cylinder hea temp sender is on.
Marc
vwmachine
Threads: 0
Mood: shity
| posted on August 19th, 2004 at 06:34 PM |
try disconnecting the wire that runs to to air intake sensor
Rolly
pay peanuts ,you get Monkeys.
all VWs are great, keep the bug alive.
Rolly
Midlife crisis
| posted on August 19th, 2004 at 07:04 PM |
Where is the air intake sensor located please
Marc
vwmachine
Threads: 0
Mood: shity
| posted on August 19th, 2004 at 07:09 PM |
in the centre of inlet manifold, (just to thr right from memory)small 2 wire plug
Rolly
Midlife crisis
| posted on August 19th, 2004 at 07:18 PM |
Hang on, there is a 2 wire plug left side of the throttle body near the back in between the 2 intake manifolds on the top is that the one ?
Marc
[Edited on 19-8-04 by Midlife crisis]
vwmachine
Threads: 0
Mood: shity
| posted on August 19th, 2004 at 07:24 PM |
yep thats the one disconnect that and see how it runs
Rolly
Midlife crisis
| posted on August 19th, 2004 at 07:25 PM |
kool thanks will give it a go .
Marc
Midlife crisis
| posted on August 19th, 2004 at 07:56 PM |
Ok went for a fair drive to warm car up. But ir made no change :-(
So back to the drawing board.
Marc
Midlife crisis
| posted on August 19th, 2004 at 08:48 PM |
Any other suggestions?????????
11CAB
Threads: 321
Mood: Beach'n
| posted on August 19th, 2004 at 09:01 PM |
Here's a question, do you have the vac hose on the pressure regulator going to the inlet manifold?
65 Meyers Manx
68 Baja Bug
Midlife crisis
| posted on August 20th, 2004 at 07:07 AM |
yep got that one on even put clamp on it to make sure
Midlife crisis
| posted on August 20th, 2004 at 03:06 PM |
I have even pit the regulator for the generator from the donor car in .
any ideas
Marc
lugnuts
A.k.a.: Mike
Threads: 88
Mood: semi-retiring
| posted on August 20th, 2004 at 08:40 PM |
I think u should buy the Bosch Fuel Injection & Engine Management book by Charles Probst,anyway in the troubleshooting section it says poor fuel
mileage could be a. idle speed,ignition timing,idle mixture(%CO) b. cold-start valve leaking c.fuel pressure incorrect.I know u said u checked for
leaks but are u 100% sure there are no vacuum leaks :kiss |
Midlife crisis
| posted on August 20th, 2004 at 08:49 PM |
In case I have missed a hose, what vacum hoses should I be checking?
Midlife crisis
| posted on August 22nd, 2004 at 04:50 PM |
Still trying to fix this problem any ideas would be great
Marc
PurpleT3
Threads: 55
Mood: knackered
| posted on August 22nd, 2004 at 05:42 PM |
i) There are one (or two) vacuum hoses going to the distributor-assuming you are running a stock SVDA unit. Are they intact?
ii)Vac hose to pressure sensor-this is a reasonably large hose which goes from under the throttle body to the sensor on the pass side of the engine
bay (this is the one 11cab mentioned)
iii)Hoses from the auxiliary air regulator.
iv)There is also a connection to the pressure switch on pre 70 models
If all the hoses are connected and not leaking, maybe check all the wiring. There are lots of wires, so it would be easy to get them mixed up.
Assuming everything is present and connected - I'm out of ideas. Trouble shooting the FI system is difficult which is why so many people ditched it
in favour of carbs as soon as it played up. I would strongly suggest that if you don't already have it you buy the Bentley manual for the type 3 and
probably Muirs' book as well. With these two books you can do just about anything.
Midlife crisis
| posted on August 22nd, 2004 at 06:15 PM |
The one to the pressure sensor is on.
The hoses to the auxilliary regulator are on . What should happen if I take the hose of the Aux Reg ?just to see if it is working.
I have been told that this is a pre 70 system but think it may be the later system where would I find the pressure switch. There is a switch under
the throttle valve switch which also makes me think it is the later model
There is a cold start valve
there is 1 hose to the dissy.
thanks for your help
marc
I have the Muirs book it is very good
Midlife crisis
| posted on August 27th, 2004 at 11:52 AM |
Well the car is running .
Took it for a drive to the Gold Coast last night went well
After playing with it for 2 and a half weeks and getting know where I did what every book said not to do and changed the ECU.
Unfortunately did not have a spare with the same numbers so what to do?
The hell wth it so I put it in and a way she went and so far so good.
Marc
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on August 27th, 2004 at 01:36 PM |
sweet...
Good to hear its ALIVE!
Tazz
1962 Type3 Squareback
1967 Type3 Fastback "Kermit"
Midlife crisis
| posted on August 27th, 2004 at 01:38 PM |
Thanks Tazz
Mark was a big help.
Now just have t see how t lasts
Marc
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on August 27th, 2004 at 01:40 PM |
Glad he could help....
He knows his stuff with the injection.....
Tazz
Midlife crisis
| posted on August 27th, 2004 at 03:53 PM |
Yeah and not just with the FI seems to know a bit about the engine has well.
He said something about sending you an email.
Marc
Tazz
A.k.a.: Tazz Devil
Old Skool
Mood: facisious
| posted on August 27th, 2004 at 05:54 PM |
me????
what did i do????
Tazz
DallanMulley
A.k.a.: Dallan Mulley
Threads: 19
Mood: OLD
| posted on August 31st, 2004 at 01:47 PM |
Tried to phone other day no luck.Your last scribe will let me sleep as I have been thinking I sold you a LEMON DJ
