| [ Total Views: 573 | Total Replies: 11 | Thread Id: 28007 ] |
lowrider
Threads: 62
Mood: O = l = O
| posted on August 29th, 2004 at 09:59 AM |
VW 5 speed
I know of an 'add a cog' conversion for sale....
anyone know anything about these & how successful they are?
An overdrive 5th in the KG would be great.
barls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
| posted on August 29th, 2004 at 10:46 AM |
i know that they require a bit of body work to fit it in as the nose cone is larger in diameter, also need a different shifter
lowrider
Threads: 62
Mood: O = l = O
| posted on August 29th, 2004 at 01:08 PM |
just reading an article in an old VW mag.
If its the same conversion, the box has a bigger nose cone
but the whole unit is no longer.
barls
Threads: 296
| posted on August 29th, 2004 at 01:12 PM |
is that the one in hot vws and dunebuggies
pete wood
| posted on August 29th, 2004 at 05:12 PM |
be worth reading the write up on 5 speeds on http://www.geneberg.com before you do
anything. I thouthg it had some really good stuff to sat and Gene was always the benchmark. He made 5 speeds before porsche if I'm not mistaken.
lowrider
Threads: 62
Mood: O = l = O
| posted on August 29th, 2004 at 05:33 PM |
I read about one by Tru-Shift in May 91
Australian VW Power.
The Gene Berg thing is an interesting read...
Buggyboy
Threads: 46
| posted on August 29th, 2004 at 09:13 PM |
5spd
Are you chasing a 5spd gearbox, I know a bloke who had one for sale, cant recall how much it was though.. let me know if you are interested and I will
chase up his number.
lowrider
Threads: 62
Mood: O = l = O
| posted on August 30th, 2004 at 06:56 AM |
I remember seeing one for sale at Action Day last year.
thanks but I think I'm over the idea now.
56astro
Threads: 74
| posted on August 30th, 2004 at 07:10 AM |
posted by barls
Why would you need a different shifter?
35MPG on 101.3kPa
Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
Mood: sweeeeet
| posted on August 30th, 2004 at 10:00 AM |
5 speed would be great IMHO but just keep in mind that most kits have the standard 4th ratio (0.89, which is overdrive at any rate) as the 5th ratio,
and shorter gaps in between. Unless you put a taller 5th in, it wouldnt change your cars cruising revs at all.
tdegens
A.k.a.: Tom Degens
Threads: 187
Mood: g
| posted on August 30th, 2004 at 06:05 PM |
5 speed
I have a 5 speed and it is getting sorted at the moment as it was jumping out of 4th. will get it back soon so it will be interesting to see how it
goes. It means that the motor revs lower and cools slower as well. Maybe why the motor was cookde out a bit. I am going to put in a t4 motor with
upright cooling if I cannot fit in the normal cooling assembly.
The 5 speed box does look pretty good stuff though and I hope that graeme from midcoast volks werks can get it together again.
Pete McC
Threads: 2
Mood: Horny as a Viking hat shop
| posted on September 1st, 2004 at 07:14 PM |
tdegens: Just because a motor is running slower and cooling slower doesn't mean it will overheat easier, the VQ engine is designed o cool itself at
the right rate no matter how fast/slow it's going, otherwise it wouldn't be safe to let it idle for any length of time, the harder you rev the
herder the fan blows, sure, but you're also generating more heat which is why it has to blow hard, if you don't generate the heat you don't need
the cooling to get rid of it. If your motor was cooked there's probably another reason, check your tinware is all there and your thermostat is
working and connected properly. If there is a problem you might as well try and sort it...
ratty 63
A.k.a.: Rossco
Threads: 74
Mood: Just cured my shed envy!
| posted on September 2nd, 2004 at 11:14 AM |
...what Pete McC said is absoloutly true - have a look around for other issues, something sounds wrong....
R
aggri1
A.k.a.: Aurel Griesser
Threads: 35
Mood: ska'd for life
| posted on September 2nd, 2004 at 12:37 PM |
Yeah but there are also some thermodynamical considerations. High torque and low speed will run hotter than higher speed and lower torque,
corresponding to equal power, which means the same road speed, for instance. But the definitions of high and low are variable.
Greater air flow (not just to cooling fan), expansion cooling, lower combustion efficiency, higher combustion pressures, I don't know, there are a
bunch of things which could affect it.
While testing an early eighties diesel for exhaust particulates, we noticed that this trend seemed to apply. On VW engines, this may correspond to
'lugging' the engine, which would be bad for it anyway, so you wouldn't do it. I suspect that the range over which a Volksie aircooled engine
works best is quite adequately cooled, as Pete said.
Still, I like the diesel principle: heaps of torque from down low. I'd love to be able to cruise at 100 doing 1500rpm. Perhaps a fifth gear would be
useful when going down gentle hills. Why have the engine hooning away at 4000rpm when it's under very little load?
