| [ Total Views: 1795 | Total Replies: 7 | Thread Id: 28076 ] |
 Zimblewinder
Threads: 23
  posted on August 30th, 2004 at 08:42 PM |
Formula Vee engines
Ive got a 1958 1200 in my splitbus and want to pick up some extra herbs for safer road life. I would like a stock appearance engine so a bigger unit
is out except up to a 1500. Im not really concerned about high speeds but acceleration would be nice. People are not so happy with cars that dont keep
up with the traffic.  I was wondering how livable a 1200 Formula vee engine would be on the road in a bus? Anyone ever tried to live with one of these
on the road? Any of the parts well woth it in a classic rebuild?  Comments please.  Cheers |
 Cam
Threads: 187
 Mood: addicted
|  posted on September 1st, 2004 at 11:37 AM |
I think the power would be the same as a 1500, probably even with less pull. You could always go for a 1500 single port and get some slide in 1640
barrels and pistons, from there some head work and overall balancing should make a nice stock looking meatier engine.... and this way you could dry
store your original motor instead of slowly wearing it out.
 Doug Sweetman
Nil Bastardo Carborundum
Threads: 58
 Mood: sweeeeet
|  posted on September 1st, 2004 at 01:02 PM |
Depending on your budget, I'd possibly even put bigger barrels on it - I assume you can flycut 1500 single port heads up to 94mm same as 1600 TP ?
94mm would give you 1915cc.
I realise it would never be a barnstormer, but if you rejetted a 34 pict carby I imagine it would be quite torquey and happy for a kombi ?
 Zimblewinder
Threads: 23
|  posted on September 1st, 2004 at 09:44 PM |
Thanks fellas a 1500 looks the go at the moment so we'll see what happens.  Cheers |
 pete wood
|  posted on September 2nd, 2004 at 07:16 PM |
I had a single port 1640 with 1300 heads on it. It was actually more torquey than my dual port 1640.
 tassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
 Mood: Moody!
|  posted on September 2nd, 2004 at 10:18 PM |
Hey
I didnt see this post.
FV engines are largely bone stock apart from some port work and (now) 38cc heads. (previously 43cc)
The camshaft is supplied by Wade but is a stock 1200 cam ground off an approved profile.
The Vee engines are usually set up with wide bearing clearances to allow them to rev a bit.
Up until the introduction of a new controlled inlet manifold, best horsepower from a $5000 second hand engine is about 44 Hp a. t. w's.
This power is up in the 4 to 4500 rev range which is useless for a road wagon.
Dont waste your time M8 with a FV engine as the horsepower you need is simply not there and you will pay a real shitload for a decent engine with
significantly less power than you could achieve with some intelligent frigging around with your stock clobber.
L8tr
E
Im not a complete idiot, quite a few parts are missing....
 oval TOFU
Bitte, ein Bit!
Threads: 234
 Mood: :booM
|  posted on September 3rd, 2004 at 10:13 AM |
| Quote: |  Originally
posted by pete wood
Why's that? (sorry. this should be in the tech section)
 Anthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
|  posted on September 3rd, 2004 at 10:34 AM |
because of the single port heads........my single port 1600 on my baja is way more torquey than my 1600 twin port engine in the super bug.
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
 oval TOFU
Bitte, ein Bit!
Threads: 234
 Mood: :booM
|  posted on September 3rd, 2004 at 11:00 PM |
So why does the restriction of the induction (and exhaust - so I've read) make for better torque? (at the expense of top end I presume)
 Adam_C
Threads: 164
 Mood: could be lower
|  posted on September 5th, 2004 at 07:28 PM |
I believe its something to do with the intake velocity......
Adam
Adzslick@iprimus.com.au
