| [ Total Views: 649 | Total Replies: 4 | Thread Id: 28375 ] |
country dubber
Threads: 17
Mood: cruising
| posted on September 7th, 2004 at 08:28 AM |
Country Buggy front end, I think!
Went to register the Country Buggy the other day and it failed the RWC because there was too much play in the king pins.
I needed parts and tried to salvage them off the spare front end I have but cant get it apart. Then I was thinking, how can I positivly tell if it is
a genuine Coiuntry Buggy front end or a Beetle front end?
:o
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on September 7th, 2004 at 09:02 AM |
On a country buggy the spindle sits lower (towards the ground) and almost lines up with the lower link pin. It is easy to identify as the spindle
wraps around the lower link pin.
On a beetle the spindle is mounted in between the two link pins.
They are visually different so if your spare "looks" the same then it is the right one.
[Edited on 6-9-2004 by MikeM]
country dubber
Threads: 17
Mood: cruising
| posted on September 7th, 2004 at 10:14 PM |
Thanks Mike. It checks out, the spindles are CB.
Just picked up on the other thread about spindles.
Are the arms that carry the links pins the same as a beetle or Kombi?
I went to register my CB the other day and it failed the road worthy because the guy said it had too much play in the king pins. I didn't have the
tools or know how to fix it so I eventually found an old VW mechanic who had all the gear and know how and I'm getting all the bushes sorted at the
moment.
The odd thing is that are arms on one side seem to be from a beetle and the other a kombi (different size link pins).
:jesus
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on September 8th, 2004 at 11:12 AM |
posted by country dubber
The Arms aren't Kombi. The common thought on this is that the arms are just beetle arms that were reamed out by the factory to take bigger link pins.
Rumour has it that some Country buggies had these large link pins and some didn't. Some Country buggies also had the large "Split bus" King Pins
and some had smaller beetle sized king pins. Confusing isn't it.
MikeM
Buggy Head
Threads: 71
Mood: :duh
| posted on September 8th, 2004 at 11:18 AM |
I have sent you a U2U. You can read these by selecting the "U2U Messenger" in the top right corner of this page.
country dubber
Threads: 17
Mood: cruising
| posted on September 8th, 2004 at 07:25 PM |
Mike, sent you a U2U (hopefully!)
country dubber
Threads: 17
Mood: cruising
