[ Total Views: 421 | Total Replies: 3 | Thread Id: 28882 ]
Author: Subject: gear box stuck in gear
MemberRISKY^VW
Threads: 61
Mood: RISKY IS 1337
sad.gif posted on September 18th, 2004 at 10:35 PM
hi people
i have a gear box that is stuck in gear there is no motor on it and it's on a pan
how do i get it out of gear??
and is it stuffed?
thanks
http://www.austech.info/forums
The best tech forum around
oh sgetty will you respect me in the morning
things could be worse you could live in kentucky
Memberseagull
Threads: 752
posted on September 18th, 2004 at 10:51 PM
you can remove the nose cone and have a play with it .
MemberAdam_C
Threads: 164
Mood: could be lower
posted on September 19th, 2004 at 08:08 AM
is the stick movable but not changing gear? if so check the basics like coupling...... ive had a coupling take a shit coming off the freeway, drove 3km in 3rd hehe
Adam
Adzslick@iprimus.com.au
Member*did*
A.k.a.: Steve
Threads: 0
Mood: happy :)
posted on September 19th, 2004 at 01:21 PM
Not sure if you have this same problem but will let you know anyway: On our buggy we have had the problem of it being stuck in 3rd, moving the gearstick didnt help at all. Open the oil filler plug in the side of the gearbox and you can carfully lever the gear back through there.
MemberRISKY^VW
Threads: 61
Mood: RISKY IS 1337
posted on September 19th, 2004 at 07:41 PM
thanks people
dose this meant the box is crap or just maybe the cone or something??
cheers big ears
Member*did*
A.k.a.: Steve
Threads: 0
Mood: happy :)
posted on September 20th, 2004 at 11:59 AM
Well if it is the same as the problem i described then it is just that someone has been trying to put it in between 1st and 3rd, shifter may need adjusting.
[ Queries: 40 ] [ PHP: 0.8% - SQL: 99.2% ]
