[ Total Views: 1249 | Total Replies: 13 | Thread Id: 29798 ]
Author: Subject: Modified rear shock towers
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
posted on October 9th, 2004 at 04:46 PM
Has anyone got some decent pics of the modified rear shock towers when converting swingaxle to IRS?
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on October 12th, 2004 at 03:15 PM
mm funnily enough
As luck would have it I sort of do, these are of a quick fix job I did for a guy who was on his way through.
Basically when you convert your pre 67 swing axle rear end to IRS you need to modify the shock towers to allow the trailing arm to swing full up travel without hitting it. If you don't modify it you will find that your arm hits the tower and the brake line often gets squashed and then ruptures.
http://www.customoffroad.com.au/brad/SwingAxleShockTower.jpg
The stock arms and tower
http://www.customoffroad.com.au/brad/SwingAxleShockTowerDuring.jpg
As you are removing some strength from the tower you need to gusset the tower to make up for it. Here I have added a 5 mm gusset plate to the outside of the tower. You DO NOT weld all the way around just up the sides.
http://www.customoffroad.com.au/brad/SwingAxleShockTowerAfter.jpg
Now you have the plate in you simply cut off the underhang. You will see the arms have the spring plate bolts removed so I can ensure they swing full travel.
After cutting clean it up and weld a strip on the bottom. I got bored of stopping to take pics about now so I don't have a finished one.
Note this job was done in the car as quickly as possible. we do them slightly differently when working on a bare pan but it is the same principle.
Brad
Meyers Manx Australia
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on October 13th, 2004 at 09:49 AM
DON'T convert an old king=pin pan to IRS...;)
Pay your debts, CxxT
posted on October 13th, 2004 at 06:39 PM
Brad...
you're my hero!! can I be your best friend? :)
so that's how you do it.
Btw, what is the tower made of?
Can I mig weld it?
or do I have to use gas and cast iron type rod?
P.s. VWcool is right, get a late model pan with IRS type towers or a semi-auto pan that already has IRS. I learnt the hard way.
Member11CAB
Threads: 321
Mood: Beach'n
posted on October 13th, 2004 at 08:48 PM
Well the problem is I dont want Balljoint front as I can get more travel from the Link Pin but also want IRS on the rear.
65 Meyers Manx
68 Baja Bug
MemberBaja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
posted on October 14th, 2004 at 08:06 AM
the easiest option would be to weld a link-pin frame head onto a superbug pan.
MemberBrad
Threads: 332
posted on October 15th, 2004 at 07:38 PM
There is nothing wrong with getting an IRS conversion done on a link pin pan. It only cost $539 inc including heavy duty pivot boxes or $450 if you supply your own. The job is fine as long as you know what you are doing.
Modifying the towers is just one of the little things you do to make it all work sweat.
Brad
MemberBrad
Threads: 332
posted on October 15th, 2004 at 07:39 PM
Oh for got to say I will add some more pics in the next week or so when I finish of the rear end of my new Manx ....
Brad
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on October 15th, 2004 at 11:55 PM
BINGO
posted on October 16th, 2004 at 09:12 AM
Brad, Wes, what the answer?
Brad...
Can I mig weld it?
What's the answer?
Member11CAB
Threads: 321
Mood: Beach'n
posted on October 16th, 2004 at 12:31 PM
A Mig Welder is fine
65 Meyers Manx
68 Baja Bug
MemberBrad
Threads: 332
posted on October 17th, 2004 at 08:13 PM
the person with the mig matters too :>
Brad
Membertype82e
Threads: 108
posted on October 18th, 2004 at 07:17 AM
which is cheaper putting a link pin frame head on a super pan? or converting the link pin pan?
marcel
posted on October 18th, 2004 at 03:44 PM
what are you saying brad, huh! :cussing
ok, guilty as charged, I promise I'll turn the gas on this time...:D
posted on November 5th, 2004 at 09:34 AM
Thanx for the tips brad, mine are all done now and ready for proper offroading. Only took an afternoon with the grinder and the MIG.
:cool:
Memberbigbaja
Threads: 23
Mood: sick of waiting
posted on November 5th, 2004 at 09:56 AM
well
marcel
It is cheaper to put a Frame head on a pan than do an IRS conversion. If you start with a super bug pan then you have all teh arms and stuff as well. BUT you need to provide a frame head to do the conversion. If you need to buy a frame head then it costs about the same both ways.
[size=4]Terry - Custom Off RoadComponents[/size]
28 Hayward Street, Stafford QLD 4053
Ph: (07) 3356 4356 - Fax: (07) 3356 6765
[ Queries: 40 ] [ PHP: 22.2% - SQL: 77.8% ]
