| [ Total Views: 506 | Total Replies: 1 | Thread Id: 30843 ] |
Wag67
| posted on October 31st, 2004 at 07:25 PM |
Clutch pedal vibration. why!!!!!!!
now we are looking at a 67 beetle for my wifes friend and I have just taken it for a test drive and the clutch is slipping and there is also a
vibration coming thru the pedal. Has anyone experienced this problem and what would cause the vibration. I know it is hard to give an answer if you
can feel it but any idea would be appreciatted. also any idea on the cost for a new clutch plate. There is some free play on the pedal so i don't
believe the clutch is adjusted wrong.
Hopefully it may be down at the gold coast dub show and take out the shitter class. it needs some TLC
Any advice or help would be appreciated
thanks
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on October 31st, 2004 at 08:24 PM |
Sounds to me the pressure plate is broken, it means the fingers on the pressure plate arent even , therefore when you press the clutch pedal it
vibrates. Also check that the welds on the clutch tube arent broken away.
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Brad
Threads: 332
Mood: Manx Buggy Building
| posted on October 31st, 2004 at 08:26 PM |
also check the bowden tube.
New clutch kit is under $250 with pressure plate, clutch plate and throw out bearing
Wag67
| posted on October 31st, 2004 at 08:51 PM |
would it also make a clicking noise as you press the pedal in if the pressure plate was broken.
