[ Total Views: 394 | Total Replies: 2 | Thread Id: 31104 ]
Author: Subject: HEI system kit
Membervoltz
Threads: 43
Mood: VW learn mode
posted on November 5th, 2004 at 05:00 PM
HEI system kit
has anyone built / has used / is using the HEI (high energy ignition) kit from Dick Smith / Jaycar etc
Im thinking of trying one with the Pertronix kit
Membertassupervee
A.k.a.: Knob Jockey
That really hurts doesnt it!
Threads: 25
Mood: Moody!
posted on November 5th, 2004 at 08:24 PM
Is that one a later incarnation of the old "Transistor Assisted Ignition" with dwell extension?
If so, I have been using these ignitions for many trouble free years on various cars.
However, the circuit provides about 1/2 an amp of "wetting" current for the points. This is to give the points something to do and to keep them clean of oil fumes and built up grunge.
This wetting current, can mess with your pointsless ignition output (as it did with mine) and cause either a failure of the triggerhead or very bad misfiring as the battery voltage rises.
There are a set of three resistors on the curcuit board just in front of the points wire connection point.
Just remove 2 of these and the system will run fine.
Iffen you ever go back to points dun forget to resolder these resistors or oil fumes and dust can eventually cause missfiring.
L8tr
E
Im not a complete idiot, quite a few parts are missing....
MembermnsKmobi
Threads: 27
posted on November 8th, 2004 at 03:13 PM
L8tr
E
Very timely. I was about to put my Transistor Assisted Ignition back on my kombi after having problems with it. In the mean time I have put on a pertronix and was wondering what effect that "wetting" current would have.
The problems I had with the Transistor Assisted Ignition were to do with misfiring. It initially went away when I changed to a new coil but then came back after driving for several hours in warm weather. After scanning through the Silicon Chip magazine web site (it's their circuit) I suspect the problem was the unit overheating. I'm going to reinstall it and see if this is the problem.
Super Administratorbarls
A.k.a.: Mr indestructible
Causer of Chaos and Mayhem
Threads: 296
posted on November 9th, 2004 at 05:48 PM
yeah the first one lasted 60 seconds and the second lasted 7 months then died but worked well when it was going
the chaos project - click me
Membertassupervee
A.k.a.: Knob Jockey
Threads: 25
Mood: Moody!
posted on November 9th, 2004 at 07:27 PM
keep us posted dude.
L8tr
E
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
