[ Total Views: 681 | Total Replies: 2 | Thread Id: 31229 ]
Author: Subject: Berg cam and straight cut cam gear
Memberwaltermitty
Mood: Hungry for mor
posted on November 8th, 2004 at 01:51 PM
Sydney . Mitchell. good. 0422 802 199, $120
Cam is used (15,000 KLm ) looks perfect to me .comes with straight cut lightweight cam gears. Below is the berg discriptuion of this cam .
GB 300 Longer duration and more lift than GB 297, designed to give more power at higher RPM. Recommended for 1700cc and larger motors with head work and dual carburetion to get smoother low end. Can be used with smaller engines but will idle rougher and lose low RPM power unless dual, dual throat carburetion is used. 1500-5500 RPM with head work. Requires GB 273A dual springs. 294 duration, 0.390" lift at cam.
23 windows ...8 too many!
Memberwaltermitty
posted on November 8th, 2004 at 09:00 PM
6
Memberwaltermitty
posted on November 10th, 2004 at 03:02 PM
MemberPeach54
Threads: 2
posted on November 10th, 2004 at 03:23 PM
Is that the cam outta my peach 1776 you bought off me. If so great work.
Memberwaltermitty
posted on November 13th, 2004 at 09:29 AM
yes mate same same. good luck with a swap yours is a beautiful oval
