[ Total Views: 1357 | Total Replies: 7 | Thread Id: 31496 ]
Author: Subject: Help!!!! Torque settings ej20t..urgent!
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on November 12th, 2004 at 10:59 PM
Hi guys,
Urgently need the flywheel bolt torque settings..cannot find them on the net anywhere.
Help me Obi-Wan Kenobi, your my only hope!
Matt
Memberseagull
Threads: 752
posted on November 13th, 2004 at 01:16 AM
74 nm will do the trick , use 277 thread locker so they dont come loose and stuff the crank !
dont for get I need your old stock flex plate bolts ( please )
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on November 13th, 2004 at 04:42 AM
No Problem...still have them, minus the 2 we had to drill.
You would not believe what happened....lock tight and torqued up..all was fine till the clutch bolts. Was used to the crank bolts and nipped one too quick and snapped off the first one.....
engine will have to wait till later on in the weekend.
Thanks seagull for the quick call...
Matt
MemberJenny
Threads: 20
Mood: Is it Friday yet?
posted on November 13th, 2004 at 07:08 AM
Matt,
the torque settings should have come with the fitting instructions for the adaptor plate and modified flywheel.
I don't have them because it was already fitted when I bought the car, but on the ricola site http://www.ricola.co.uk/KEPfit.htm  he torqued the flywheel bolts to 50ft/lbs.
Memberseagull
Threads: 752
posted on November 14th, 2004 at 01:03 AM
No probs Matt
Memberspeedster356
A.k.a.: Peter Mcleod
Plastic not Classic Racing
Threads: 256
posted on November 14th, 2004 at 09:18 PM
Flywheel bolts are 69-75 Nm or 51-55ft lbs
the clutch bolts are 15.7 Nm or 1.1ft lbs
MemberJenny
Threads: 20
posted on November 15th, 2004 at 08:10 AM
speedster356,
I think you had a typo, 15.7Nm is about 11.6ft/lbs, not 1.1!
Memberspeedster356
Threads: 256
posted on November 15th, 2004 at 05:02 PM
Yikes , sorry bout that........that would be almost hand tight!!!
Memberseagull
Threads: 752
posted on November 15th, 2004 at 11:11 PM
well what can I say Peter us fitters did not get it right !
um what was the lenth of the * new bolts * for the fly wheel Matt ?
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on November 16th, 2004 at 08:26 PM
Did not measure them..
All new bolts for the clutch also and the motor is back in...hopefully only a week or so to go....hopefully.
Matt
[ Queries: 40 ] [ PHP: 8.9% - SQL: 91.1% ]
