[ Total Views: 918 | Total Replies: 6 | Thread Id: 31627 ] |
robnjo
Threads: 254
Mood: its tricky tricky tricky
posted on November 15th, 2004 at 08:26 PM |
Split bus devider replacment
has anybody done this before?...maybe pissed off the walk-through set-up or replaced one that has been hacked at, like mine.
where do I start? how (drill..5mm??)
Rob King,Andrew or anybody who has done this before
Rob
Error |
robnjo
Threads: 254
posted on November 15th, 2004 at 08:27 PM |
my replacment one
Error |
ClassicVW(pacific)
Banned
Threads: 141
posted on November 15th, 2004 at 08:31 PM |
robnjo
Threads: 254
posted on November 15th, 2004 at 08:32 PM |
so should I just drill out these spot welds ?
its the bottom seam I'm worried about :jesus
Error |
robnjo
Threads: 254
posted on November 15th, 2004 at 08:35 PM |
so Roy is that what the bit is call...spot weld bit?
57kombi
Hannover Elder
Threads: 181
posted on November 15th, 2004 at 10:51 PM |
The only way to do it is grind the replacement on down and drill out the spot welds on the one that is in the bus.
Dave
twoguns
simply aircooled
Threads: 226
Mood: simply cruizin'
posted on November 16th, 2004 at 12:15 AM |
if its only the wheel arch that is hacked, then why not jsut cut and replace that section? jsut wondering.
Simply Cruzin'...
robnjo
Threads: 254
posted on November 16th, 2004 at 05:17 PM |
thanks Wes, maybe this is a better idea, was talking to "dub" & he said that this way is on the money too.
nicko
Threads: 77
Mood: Tired
posted on November 17th, 2004 at 12:47 PM |
How far is the panel in the car cut down to? The divider panel from what I can see in my bus goes all the way down to the lower edge of the top hat
and it is welded to the top hat. If you dont need to replace the top hats I would be trimming your replacement panel to meet the remaining top edge of
the existing panel and then getting a welder who knows what they are doing to butt weld the join. When you are drilling the spot welds out try not to
drill through any parts that you want to retain. This will allow you to use a hand held spot welding gun to redo the welds particularly on the visible
areas. Most panel beaters have this type of welder but I reckon you should talk to one before you start cutting.
Cheers Nicko
