[ Total Views: 696 | Total Replies: 5 | Thread Id: 32297 ]
Author: Subject: Freeway flyer Splitty gearbox 4 sale
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on November 29th, 2004 at 02:56 PM
Reconditioned big nut reduction box gearbox for a split Kombi, based on a '74 1300 Beetle gear box, it is fitted with a 3.88 ring and pinion from an "L" bug, stock 1st 2nd and 3rd gears, but fitted with a tall .82 Kombi 4th gear, to give about 3,200 rpm in top gear at 60 mph.
It was recoed by Shimo, and I did the reduction boxes, including all new bearings. has done 1,100 miles.
Ideal for someone wanting to keep their bus stock but keep up with the traffic.
Price is $900.00
Located in Nowra, still in my bus so it can be test driven.
Phone 0402 003965
FAHRVERGNUGEN;
Memberwaltermitty
Mood: Hungry for mor
posted on November 29th, 2004 at 04:32 PM
Dave , Yes I would like to keep up with the traffic more easily so i am interested why are you selling it? did it live up to your expectations? Is it very different to standard? what is the drivability like? and does it suit a 1500?
Mitchell
23 windows ...8 too many!
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on November 29th, 2004 at 05:08 PM
I stock 1500 will struggle a bit up hills, idealy a 1600 twin port engine at least would make it nice to drive, I have a 2007cc with twin carbs behind it now, it drives very well.
FAHRVERGNUGEN;
Memberbeerdoc
A.k.a.: Doc
Threads: 42
Mood: Its all good
posted on November 29th, 2004 at 08:00 PM
Dave
That would really suit a 66 panel that I could get on the road real quick and drop a 1776 with twin webers to work out of and drive geelong melb every now and then
But I dont need it for at least a year and cant afford it now
If you still have it then I could be your man
Cheers Doc
reVOLKS at Fyansford Geelong
Member57kombi
Hannover Elder
Threads: 181
posted on November 30th, 2004 at 09:43 AM
not trying to upset anyone but couldnt you get a IRS fitted for that price and if you are wanting to keep it stock why would you then have to have a 1600tp to drive it.
Isnt that defeating the objective of keeping it stock???.
Straight axle would be cheaper and give you a higher final drive without the reduction boxes.
Dave
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on November 30th, 2004 at 06:09 PM
Dave
Straight axle would be cheaper but makes you bus drag its arse on the ground, so the front needs to be lowered to match.
This gearbox bolts straight in, looks stock, (heights, camber etc) and it still drives like a stock splitty, and makes all the right noises!!! like a stock splitty does, just has longer legs so it can cruise comfortably at 65-70 mph.
FAHRVERGNUGEN;
