[ Total Views: 371 | Total Replies: 3 | Thread Id: 33083 ]
Author: Subject: changing 4 stud to wide 5
Memberwrecker67
A.k.a.: craig
Theme: UltimaBB Psyche Green
posted on December 17th, 2004 at 03:12 PM
i have a 67 that has been change to the later 4 stud.well i want to go back to wide 5 ,this is on the rear,do i just use the backing plates and drums from a wide 5 bug.is this a straight bolt on job.......
cheers...
To follow the path: Look to the master, Follow the master, Walk with the master, Become the master
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on December 17th, 2004 at 04:13 PM
If it is still the narrow rear end, you should only have to use the 5 stud drums and swap them for the 4 stud ones,
If it is a later wide rear end, they will swap over too but you need to use a spacer under the 36mm nut as the spline is shorter on the early drums.
FAHRVERGNUGEN;
Memberwrecker67
A.k.a.: craig
posted on December 17th, 2004 at 04:27 PM
thanks for that sounds to easy.........
cheers for that dave........:beer
Memberkarmannghia60
Karmann Ghia Sucker
Threads: 388
posted on December 17th, 2004 at 05:37 PM
I think the front bearings are different too
