[ Total Views: 547 | Total Replies: 2 | Thread Id: 33326 ]
Author: Subject: What is usual running temp for 2l Kombi
Membersnifter
Threads: 71
posted on December 24th, 2004 at 03:48 PM
I have just fitted a dipstick temp sensor to reco motor. It runs at 110 c on the flat on a windy day doing 80ks.
What is not good? What temp is too hot and time to pull over????
Ta
Philip
posted on December 24th, 2004 at 04:29 PM
it all depends
130 is shut down
100 is nice
70 is cold
You "should" be abouve 90 to get the impurities out of the oil. 110 is maybe a bit high for those conditions.
Wouldnt worry just yet. As i said , it is all relative. IF everything is fine them things can read hot if it is near metal for eg.
Best place is in the case or that plat in a Type 4. I would be more interested as to how it moves. Does it climb to 130 if cruising at 100k?? or only say 105??
Does it "small" hot???
Membersnifter
Threads: 71
posted on December 24th, 2004 at 04:47 PM
The engine is still in its run in phase. It was a very windy day. New seal in engine bay. Very flat road. It is a dip stick sender. Dont want to run at 100k for a while to comply with rebuilders instructions.
ta
Philip
