| [ Total Views: 609 | Total Replies: 5 | Thread Id: 33418 ] |
akean1
A.k.a.: Dr Akean
Remember To Love
Threads: 90
Mood: On my bike...
| posted on December 27th, 2004 at 08:56 PM |
external oil cooled bugs
has anybody got info on, or preferably photos of instaling external oil coolers on beeetles, the ones that use those 8inch thermo fans? and where is
the best spot to mount them |
BiX
Threads: 154
| posted on December 28th, 2004 at 10:56 AM |
i run a external cooler above the gear box. It is extra aboe the std dog house one. O used some alloy bent in elbows to hold the top, then some
threaded rod mounted down to hold the bottom. i found the engine runs very cool, and in winter i don't need the extra cooler.
Go hard or go home!!!!
akean1
A.k.a.: Dr Akean
Remember To Love
Threads: 90
Mood: On my bike...
| posted on December 29th, 2004 at 09:18 AM |
thanks bix, iwas going to set it up permanent. sounds like i should put a switch in |
akean1
A.k.a.: Dr Akean
Remember To Love
Threads: 90
Mood: On my bike...
| posted on January 9th, 2005 at 02:56 PM |
was just reading up on gene berg web site , said that they had done numerous tests on modified cooling systems, with the best result coming from
standard dog house type fan, second best was standard fan shroud. also said that when changing from standard fan to wider dog house type to use
vented deck lid to allow more air in... |
vassy66T1
A.k.a.: Marcus Vass
Wow ... are U reading this?
Mood: Happy to own a VW
| posted on January 11th, 2005 at 01:20 PM |
Having run a 1776 myself with and without an external oil cooler, I would say they are fantastic. Yes keep the doghouse cooler, but the extra with the
thermo fan really helps the engine run nice and cool.
Mine never got past 90deg even on a hot QLD day
Marcus
:P
AdrianH
Threads: 20
Mood: rebuilding again
| posted on January 11th, 2005 at 07:07 PM |
You can get an inline thermostat that allows oil to bleed past, but doesnt fully open until it reaches 180ish F - so it bypasses the cooler when the
oil is cold (Bugpack make one). You can also get a thermo switch for the fan so it only switches on when the oil gets hot.
