[ Total Views: 560 | Total Replies: 11 | Thread Id: 33664 ]
Author: Subject: v6 T2 pics of radiator
Membervwtyp2
Mood: over it
posted on January 4th, 2005 at 05:34 PM
here's where the rad sits in my v6 bus.
the rad is from a hx holden v8.
it has a thermo fan on the back to blow air through.
[Edited on 4-1-2005 by vwtyp2]
Membervwtyp2
Mood: over it
posted on January 4th, 2005 at 05:38 PM
there's a duct that sits behind the beam to direct cold air through the rad.
Membervwtyp2
Mood: over it
posted on January 4th, 2005 at 05:41 PM
view of top of rad.
sits neatly between chassis rails, and on an angle so air passes through it easily.
Membervwtyp2
Mood: over it
posted on January 4th, 2005 at 05:44 PM
here's another pic of the air duct.
Membersikdub
Mood: svweet
posted on January 4th, 2005 at 07:58 PM
Hey man, nice set up. how much ground clearance would this sacrfice if any?
Membervwtyp2
Mood: over it
posted on January 5th, 2005 at 08:23 AM
about 100mm.
you can see in the 2nd pic that the exhaust hangs dorn lower than the cooling.
this will change very soon though. :)
Membersikdub
Mood: svweet
posted on January 5th, 2005 at 01:59 PM
Ta. It's wicked, very interesting
Member57 Chook Shed
Mood: ? No thanks.
posted on January 5th, 2005 at 10:12 PM
Would I have any ground clearance issues if I fitted it to mine??
MemberAlex Holzl
A.k.a.: Big Al
2332cc of pure BALLZ!!
Threads: 85
posted on January 5th, 2005 at 10:15 PM
hahaha nar not at all!
Membervwtyp2
Mood: over it
posted on January 6th, 2005 at 09:17 AM
should be o.k. Gra.
hangs down 100mm from chassis.
I can show you how, if you show me how to get down that low. ;)
Member57 Chook Shed
Mood: ? No thanks.
posted on January 6th, 2005 at 10:42 AM
It`s easy, who needs all those torsion leaves!??
MemberKlaus
Threads: 100
Mood: Heavily modified
posted on January 8th, 2005 at 08:46 PM
hey thats how i had the vn v6 rad fitted but I couldn't relocate the outlets mmm , changing mine to up front as the kombi gets a lot of offroad use, also want to get a an all alloy rad due to the fact I burst the end plastic end tank one up on its second outing ( pretty common for these ones).
[ Queries: 40 ] [ PHP: 8.8% - SQL: 91.2% ]
