[ Total Views: 414 | Total Replies: 16 | Thread Id: 35948 ]
Author: Subject: weird problem?
Membermoonlite6t6beetle
A.k.a.: Corey Marriott
Threads: 80
sad.gif posted on March 8th, 2005 at 09:08 PM
weird problem?
My beetle is an extremely reliable car, and have never had alot of problems with it.. however just recently for no reason what so ever, it will just die... like is run out of fuel.
It happened one and i just figured it was the fuel filter, replaced it and had no problems but however today it did the same thing again, i honestly dont think its the filter again.
But what do you guys reckon?
Need to fix tonight so ANY help will be appriciated.
Corey
Moonlite... 54 and 66 beetle
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on March 8th, 2005 at 09:29 PM
Hmmm, having replaced the fuel filter once before which solved the problem temporarily suggests it may be related to fuel delivery problem.
Possible explanation may be vapour lock (like the fuel tank creates a vaccum and doesn't allow the fuel to flow especially on hot days). Check the fuel filter again - is it blocked with crap again - query crud in tank.
There will be other people with other ides hopefully.
One other cause of my bug dying unexpectedly then reviving then dying again for no special reason was a faulty condensor on the dizzy. Would be worthwhile trying to change that (not too expensive).
Memberjenz58
Postal Menace
Threads: 230
Mood: Cruisy
posted on March 8th, 2005 at 09:30 PM
I had that problem....ages ago...I need to really think to remember what it was now....buggar...will be back
Memberjnr356
Threads: 33
Mood: casual
posted on March 8th, 2005 at 09:36 PM
blocked needle and seat
http://s23.postimg.org/vl55hvvev/flipinthebirdcopy3.jpg
Memberjenz58
Postal Menace
Threads: 230
Mood: Cruisy
posted on March 8th, 2005 at 09:37 PM
Fuel pump.....
Member11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
Do you have a tacho fitted? If so it could be the wire from the coil to the tacho shorting to earth.
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
MemberMickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
posted on March 8th, 2005 at 10:17 PM
Sounds like there might be some crap in the fuel tank blocking the outlet. Try blowing back through the fuel tank. Was the old filter blocked/full of crap?? Before you blow it:duhtake the fuel cap off.Good luck!!
tssnq.com.au
Memberbugeyedbabe
Threads: 64
Mood: In love with a SMURF
posted on March 8th, 2005 at 10:26 PM
how long ago did u replace fuel filter, and is it dirty again (have u checked)
what sort of fuel are u running thru it...
these may help give idea ....
is there a put put sound before it dies. r u stopping half tank/full tank.
how often has it happened...
ie had it 5000K did it twice, 2800k and 5000k every 2500K at 4000k and 5000K.
what heat were u generating, what was day like.
i know these sound stupid, but all may help.
I worked as auto electrician, and had cars come in when each of these related to problem.
dubless. :fakesniff:
posted on March 8th, 2005 at 10:33 PM
Does it only happen when you are on a quarter of a tank or less - specifically after going through a few corners?
Also - drop a tank full of premium unleaded in to help clear the cobwebs.
Squiz....
posted on March 8th, 2005 at 11:37 PM
When I had this problem, it was the condenser....
when it got cool it would work.... again...
Check wires going to coil- points etc that they cannot touch any metal...
Coil High tension lead not touching earth.... and shorting to earth... Girl had that problem and called the NRMA each time
they took the dizzy lead off and checked everything... then it would go OK as the NRMA guy had moved the high tension lead.... this went on for weeks.... then one night the girl said to the NRMA "stay & Fix the problem" and He found the High tension lead from the Coil to the Distributor shorting out in the dark....
You don't have a loose wire going to the electromagnetic fuel cutoff valve in the carby...?
Either electrical or Fuel....
I took the little strainer in the bottom of the fuel tank off My Beetle..... I have an external fuel filter under the tank....
Best of Luck
Lee Noonan
mad.gif posted on March 8th, 2005 at 11:40 PM
I just remembered : If Your Points are pitted or burnt
Your Condenser needs replacing...
A New condenser will fix the pitting/burning of points...
Maybe Your Coil is breaking down internally when HOT..??
Memberbugeyedbabe
Threads: 64
posted on March 8th, 2005 at 11:42 PM
i love that motor lee...the colors look so pretty
posted on March 9th, 2005 at 12:06 AM
thanks for the compliment on the engine....
underneath is the same.... front & rear suspension....
I just like fiddling with paint....
Here is a pic of My blue rear axle & yellow shock absorbers..
For the fellow with engine stopping....
Put a fuel filter before Your pump and check to see if it has any fuel in it... when the engine stops again....
could be something floating around in the tank...
this is a common problem in the USA.... I don't know why??
If it does have fuel in it, put the filter after the fuel pump....
and check again....
MemberbugDbug
Threads: 19
posted on March 9th, 2005 at 07:48 AM
I would test the obvious to narrow down the problen Check if you have spark. If you do then squirt some petrol down the carb and try to start it and see if it kicks over for a second then dies.If it does then its fuel problem
Good luck
Bob
[Edited on 8-3-2005 by bugDbug]
MemberBungawatta
Mood: Zekkocho
posted on March 9th, 2005 at 09:51 AM
It could be the cut-off valve on your carburettor, if there is one, that maybe getting a bad connection.
If you can observe when the engine dies and you hear a "click" from the carburettor, then check and fix its wiring connection. :)
MemberBungawatta
Mood: Zekkocho
posted on March 9th, 2005 at 09:54 AM
Ooops, already mentioned by 68AutoBug. Sorry.
MemberQueen_Bug
Threads: 9
Mood: FREE AS A BIRD
posted on March 9th, 2005 at 10:33 AM
I was the same as 68Autobug, once I had the condenser replaced it was fine, haven't had a problem since
