| [ Total Views: 608 | Total Replies: 6 | Thread Id: 36523 ] |
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on March 19th, 2005 at 06:53 PM |
Hydraulic Lifters in a 2L type 4
So has anyone converted from manual lifters to hydraulic lifters on an aircooled type 4?
I know that the later ones came out with hydraulics, but has anyone done the conversion?
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
| posted on March 19th, 2005 at 09:54 PM |
Have a scroll through this thread for starters....titled "swapping hydraulic lifters for solid"...so should be what you are after.
http://www.shoptalkforums.com/viewtopic.php?t=1333&highlight=hydraulic+li...
Oh and this one:
http://www.shoptalkforums.com/viewtopic.php?t=76233&highlight=hydraulic+l...
...and a little of this one:
http://www.shoptalkforums.com/viewtopic.php?t=73715&highlight=hydraulic+l...
the search function will yield a lot of great info on most forums
Alan
11CAB
Threads: 321
Mood: Beach'n
| posted on March 19th, 2005 at 10:23 PM |
Thanks Alan, I'd already done that search, but it seems the americans are swapping hydraulic for solids not the other way around....they obviously
dont like them. But I've recently pulled down a T3 aircooled engine that has them, and it has got over 300,000klms on it with no damage to the
cam....the only reason the motor was stripped down was the customer has had the van 20 years and wants it to last him another 20 years.....
I like the idea of quieter running and not having to adjust the tappets again.
Some interesting info that I've found is that the solid lifters use an aluminium pushrod 270mm long while the hydraulics use a steel pushrod 260mm
long.
65 Meyers Manx
68 Baja Bug
11CAB
Threads: 321
Mood: Beach'n
| posted on March 20th, 2005 at 11:19 AM |
Well it works in the short term....I fitted them up today with the modified push rods and its nice and quiet....no noticeable difference in
performance, but its definately not worse.....we'll see if its all doom & gloom in the future as the americans seem to think...
Graham
65 Meyers Manx
68 Baja Bug
Dasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
| posted on March 20th, 2005 at 09:39 PM |
Good stuff Graham, hope it all works out well for ya! Would be nice to not have to adjust tappets I agree.
mnsKmobi
Threads: 27
| posted on March 24th, 2005 at 11:18 AM |
I suspect the Americans swapping from hydraulic to solid are doing so as part of building performance engines b/c (IIRC) there are a lot more cam
options for solid lifters. There are also a lot of Americans with stock and mild engines who seem to be very happy with their hydraulics.
sand kombi
Threads: 71
| posted on March 24th, 2005 at 11:27 AM |
Graham, Try John Alder as I had hydraulic ones in my twin cab, apart from the occassional rattle on start up, I never had any problems with them
Mike
MIKE.
VW'S DON'T LEAK OIL, THEY JUST LEAVE THEIR MARK !!!
