[ Total Views: 583 | Total Replies: 4 | Thread Id: 36697 ]
Author: Subject: super bug pan
Membert2
stop taking life so serious
Threads: 206
Mood: tired
posted on March 23rd, 2005 at 05:39 PM
super bug pan
this q might b obvious to all you out there in vw land but will a early beetle body fit onto a super bug pan (71). if so is it a straight forward swap
thanks darren
gravity wont get you high
MemberRISKY^VW
Threads: 61
Mood: RISKY IS 1337
posted on March 23rd, 2005 at 05:52 PM
na it won't
you would need to weld in a new frame head the get a front beam
not worth it
http://www.austech.info/forums
The best tech forum around
oh sgetty will you respect me in the morning
things could be worse you could live in kentucky
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on March 23rd, 2005 at 05:55 PM
Easy fit, no.
You would have to change the frame head for the front end, so you can bolt the earlyer torsion bar front suspension to, there is no way that you can use the strut front suspension off the super with out major mods.
The floor pan holes of the super bug pan will match the early body, but the rear mounts on the early body will have to be shortened to fit the super pan.
Hope this helps
FAHRVERGNUGEN;
MemberDIY-DUB
Threads: 288
posted on March 24th, 2005 at 03:36 PM
t2 there is something on germanlook that has a super pan with part tube chassis/roll cage out the front 2 mount the struts 2, would be exteremly expensive tho, unless ur a crazy german modder
posted on March 24th, 2005 at 04:05 PM
It can / has been done
http://www.clubvw.org.au/jurgo.htm
this car is actually a Super. the pan was perfect and it was a better choice to weld on a new head.
The car was worth it. It is wonderful.
I didnt say it was cheaper or easier
Barry
