| [ Total Views: 584 | Total Replies: 3 | Thread Id: 36832 ] |
orange
Threads: 28
Mood: ok
| posted on March 28th, 2005 at 01:44 PM |
to drive or not to drive
My 1600 kombi was make strange squeak noises when changing engine load. The noise come from passenger side.
I drove from Brisbane to Gympie 2.5 hours 150km.
When I got to Gympie I removed the valve cover. 3 studs out of the 4 I can see are loose, real loose.
Tightening them down just lifts the stud. Using two bolts together I can tighten move the studs back down, but they are easy to turn with an open
spanner. Anyways I nip the nuts back up but there is not much tighness before the stud turns. It drives for about 500 meters - 1 K before the head is
rattling, and the 3 are loose again.
What to do? I think not try and drive back to Brisbane.
Anyone know a VW mechanic in Gympie?
Can studs be tightened at the case end once I got the engine out?
Cheers, Carl.
64vwmark
A.k.a.: Mark Shepherd
Threads: 82
| posted on March 28th, 2005 at 02:07 PM |
I would just take it to a mechanic and get it sorted once and for all.
Beach Buggy
74 L Beetle
Mk4 Golf
BiX
Threads: 154
| posted on March 29th, 2005 at 01:10 PM |
it sound like you have pulled 3 studs. from what i understand you may have to pull the engine and get helicoils put in the case. somebody with more
experince should be able to provide more info.
Go hard or go home!!!!
VWENVY
More Common Than Most
Threads: 17
| posted on March 29th, 2005 at 01:21 PM |
I used self-tappeers in a t3 once, the engine case was fatigued, and i had no options at the time. 5 studs (3 on 1 side and 2 the other) were
replaced with self-tapping studs. Just replaced the studs with engine in tact! Thess got me from Brisbane to Sydney to Melbourne then Brisbane in one
go, and a shit load of k's after that with no problem. I think you'd be sacrificing the case in the long run but if it gets you out of a spot it
might be worth a thought! Just keep on top of valve adjustments! I got them from ye sadly departed Volksrestore 10 years ago, so they should be
available!?
Good Luck!!:duh
