[ Total Views: 581 | Total Replies: -1 | Thread Id: 3846 ]
Author: Subject: 71 super lowering
Member555bug
WRX Bug Boy
Threads: 79
Theme: UltimaBB Vintage
Mood: turbo charged
posted on February 19th, 2003 at 02:28 AM
71 super lowering
OK I've got a 71 super beetle that I want to lower. I've got some whiteline springs (40~50mm lower). So whats next? can I just use a standard insert and cut the stops or is there a nicer solution? golf inserts?
posted on February 19th, 2003 at 07:19 AM
Buy them already done and set up.... available here in Sydney. 02-9789-1777
[Edited on 18-2-2003 by vw54]
posted on February 19th, 2003 at 07:30 AM
you need golf inserts and adjustable struts if you want to do it right.
Go to
http://www.clubvw.org.au/
Then stories from our club magavine > struts and stuff
Good article by Steve C
Another good place is
http://www.superbeetlesonly.com/frameset.html
go to Tech and Stuff
as well as the forums under Technical > Suspension.
I have just dumped Blue with the help of V Force. He sells the adjustable strut if you are interested.
It is custom made with a Kings spring and Saachs insert.
Memberjakriz
Threads: 46
Mood: 2 headed
posted on February 19th, 2003 at 06:35 PM
Do what Baz says & call Richard at V-Force, 0297431247 & he's cheaper than everyone else as well.
Jak
Congratulations to Ben Durie for breaking the hillclimb record at Ringwood in his stroker beetle!
