| [ Total Views: 857 | Total Replies: 6 | Thread Id: 39140 ] |
baybuscamperkid
Threads: 335
Mood: transported
| posted on May 14th, 2005 at 07:49 PM |
waterloss from subi engine
although my car seems to have been cruising nicely with its subi ea81 engine, it is loosing ALOT of water, as in upto 4l within 100km! doesnt appear
to eb any real sign of it coming from the radiator cap (which is new) the top heater hose appears dry, the 2 hoses appear dry where they mount to the
radiator appear dry and there is no sign of water leak when the car is stopped. any ideas where the hell all this water could be going?
MickH
A.k.a.: Michael Hutchinson
Hairy Gutted Sloth
Threads: 29
| posted on May 14th, 2005 at 08:14 PM |
Get a pressure test done on your system. Thats a lot of water to be getting "lost" Hope it's not getting into your cylinders....via a head gasket
leak..
tssnq.com.au
pod
A.k.a.: paul mrvw061
Mood: could be better
| posted on May 14th, 2005 at 08:23 PM |
or from cracked or corroded heads,as my sons vl commodore had corroded water jackets into combustion chamber,it had coolant injection:o because
previous owners ran straight water instead of coolant with a alloy head
gayanne
Threads: 3
Mood: Pure Tubular Adrenalin Subie Power
| posted on May 14th, 2005 at 10:22 PM |
Check the dip stick for water in oil.JVLRacing
baybuscamperkid
Threads: 335
Mood: transported
| posted on May 15th, 2005 at 09:36 AM |
havent noticed any milky oil yet, but was intending to check again today.
gayanne
Threads: 3
| posted on May 15th, 2005 at 10:51 AM |
If not boiling and deffently no leaks,dump the oil just to be safe.JVLRacing.
baybuscamperkid
Threads: 335
Mood: transported
| posted on May 15th, 2005 at 08:48 PM |
just checked the oil again after puttering around today and definitely no water in it. found that i was missing a thermostat, so replaced that today,
re-adjusted the bottom hose on the radiator (looked like it may have been leaking a little there under pressure) sounded like it did boil a little
today, but think/hope that is mostly cos we over-perssurised it (put the cap on whilst revving) looks like a trip to a pressure tester soon.
