[ Total Views: 793 | Total Replies: 1 | Thread Id: 39185 ]
Author: Subject: Seam sealer first or primer ?
Member1303
Threads: 42
posted on May 15th, 2005 at 05:23 PM
I have done a little work beefing up the area behind the back seat of my beetle. I removed alot of the old seam sealer so I could weld gussets and some 200mm x 200mm x 2mm shaped steel plates on each side.
Will I need to apply seam sealer prior to primer or vice versa?
I was just going to spray on etch primer after seam sealer until I get it resprayed.
Cheers Paul.
Memberkillakornkobb
A.k.a.: Damien
where's that clutch?
Threads: 149
Mood: Pierced
posted on May 15th, 2005 at 06:19 PM
etch prime, then seam sealer, then primer before colour... allow 25-30 mins for seam sealer to go chewy before applying 1 coat of high solid 2k primer, allow flash off, and paint colour.. no sanding of the 2k primer :)
Tagedeezee Heezy
[ Queries: 40 ] [ PHP: 13.7% - SQL: 86.3% ]
