[ Total Views: 611 | Total Replies: 8 | Thread Id: 3938 ]
Author: Subject: moisture in dizzy
Super Moderatorkombi_kid
Good Kid too many projects
Threads: 341
posted on February 23rd, 2003 at 12:25 PM
moisture in dizzy
hey
after it rains (not very often) there is always moisture gettin into the dizzy!!! and u cant start it!!!
it is put on right i think it might be the little black cover between the cap and the points etc????
rhys:kiss
Memberamazer
kombi pilot
Threads: 308
Mood: Peachy!
posted on February 23rd, 2003 at 05:36 PM
close the engine lid!
Threads: 341
posted on February 23rd, 2003 at 05:53 PM
tis closed! has louvers in it though?
posted on February 23rd, 2003 at 06:39 PM
Should have the black disc thing under the rotor that covers the points. Dont know how much it would affect it though.
I am rumming stand offs if this pouring rain and i have no problems.
I reckon you got a crack.
MemberREDKG
posted on February 23rd, 2003 at 08:34 PM
is this problem on your brother's beetle?
posted on February 23rd, 2003 at 08:39 PM
get some CRC or WD40 or even a new cap might fix the problem
Threads: 341
posted on February 24th, 2003 at 07:07 AM
yer its in bros beetle!!!
ok ill look at the cap spray some Inox in it and it rained last night so ill go chek it out/!!!!
thanks guys
rhys
Memberaussiebug
A.k.a.: Rob Boardman
Threads: 3
posted on February 24th, 2003 at 12:40 PM
Rhys,
Some bugs are more suseptible than other to water on the distributor.
You can sometimes improve the situation by removing the wires from the distributor cap and giving it a complete wipedown with paper towels or rags to remove all the dust on top - this makes an excellent moisture trap so you get cross-firing arcos the top of the cap. Pull the coil main iwre and clena around that terminal too - same deal with the dust.
If you have a two-slot lid on that bug, they originally had rain trays under the lid to drain water out the bottom of the lid. If it's a 4-slot lid (72+ cars) - they have no rain tray (no room for it with the larger paper air cleaner) and the engine does get a little wet.
Keeping a can of WD40 handy is a good idea (it will usually cures a wet-start problem), but it has a downside - if you leave the WD40 on the distributor cap it eventually dries out and dust then sticks to it - starting the process all over days or weeks later - so the cap still needs a good cleanup.
Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com
Member56astro
Threads: 74
posted on February 24th, 2003 at 01:12 PM
Rhys
Whatever you do, DON'T spray WD40 or similar in dissy and try to start immediately. WD40 is flammable ("refined kero and peanut oil";). My auto elec. told me he has seen a dissy blown to pieces when someone did this.
35MPG on 101.3kPa
MemberKruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
posted on February 24th, 2003 at 01:31 PM
Kool!!! That would have to be even better than those clear dizzy caps! :D:D
Kruizin Kol
Threads: 341
posted on February 24th, 2003 at 03:25 PM
im pretty sure its a 009 dissy!
rhys
MemberOvalGlen
Threads: 46
Mood: Change
posted on February 24th, 2003 at 08:29 PM
So kombi kid has it got the plastics disk in?
Regards,Glenn>
Threads: 341
posted on February 24th, 2003 at 09:13 PM
yer
[ Queries: 40 ] [ PHP: 2.5% - SQL: 97.5% ]
