[ Total Views: 1680 | Total Replies: 20 | Thread Id: 39860 ]
Author: Subject:  First ride!!!!!
Membersubaruboxer
Threads: 20
posted on May 29th, 2005 at 06:54 PM
First ride!!!!!
Three days ago, I rode my bug with Subaru EJ 22 out of the garage and hit the Autobahn. It was such a good feeling after all the work and time. But it is worth all that.
I made 100 kp/h at exactly 3000 rpm, and 180 kp/h at 5600 rpm. That was great. When going 180 kp/h it hit me for a second: You had the car completly apart ! Are you sure that everything is tight ? You have no safety belt or airbag !
Okay we die like real men!
Here some facts of my bug, as I have to check the accuracy of my speedo and tach:
car: 65` bug with 68`IRS pan
trans : 1303 S (L-bug box)
wheels: 5,5 X 15 Porsche steel
tires: 185/65/15, circumference 1931 mm
"slowness is an ornament, you are faster without it"
[Edited on 29-5-2005 by subaruboxer]
[ Edited on 4-2-2006 by subaruboxer ]
Memberbigbaja
Threads: 23
Mood: sick of waiting
posted on May 29th, 2005 at 09:03 PM
can you send me some pics of your conversion please
tezcat@customoffroad.com.au
thanks
[size=4]Terry - Custom Off RoadComponents[/size]
28 Hayward Street, Stafford QLD 4053
Ph: (07) 3356 4356 - Fax: (07) 3356 6765
posted on May 29th, 2005 at 09:43 PM
congrats, I know the feeling, it's great :thumb.
Had my buggy out tonight myself
Membersubaruboxer
Threads: 20
posted on May 29th, 2005 at 10:14 PM
bigbaja,
for pics of my conversion , please check my posts here.
For exsample: My cooling system. Lots of detail pictures.
thanks
Member72RSbug
Threads: 49
posted on May 30th, 2005 at 12:33 AM
congrats, can't wait for that day to arrive myself
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on May 30th, 2005 at 08:19 AM
so unasuming... I like it, I like it alot!
What is the little wire down the side????? I just fed all mine through the heater tube straight under the back seat.
I might go for a spin this morning also.
Matt
Membersubaruboxer
Threads: 20
posted on May 31st, 2005 at 05:02 AM
Matt
Hi Matt,
that little cable down the side is of my LCD thermometer that is standing on the handle above the glovebox. Look close and you can see it. I was always a bit concerned about the open airfilter over the hot engine. I wanted to check the temps of the intake air right at the first ride. And would you believe, that it was 15 to 30 degrees celcius higher than ambient air. Anything less than 5 degrees higher is good, so this is bad. I cut a big hole under the licenseplate and even under the light for the licenseplate, both not visible. And I will install a fan behind the license plate to blow the hot air out.
[Edited on 30-5-2005 by subaruboxer]
MemberBrad
Threads: 332
Mood: Manx Buggy Building
posted on May 31st, 2005 at 08:22 AM
That is good to hear... 180 kmph in a bug after a rebuild that is cool .....
Congrats I look fwd to seeing your Dyno results
Brad
Meyers Manx Australia
MemberVWCOOL
Threads: 235
Mood: happy to help
posted on May 31st, 2005 at 08:51 AM
Originally posted by VWENVY
sounds like you need hoodjax!?
I WAS JUST GONNA SAY THAT!
First of all, [size=6]CONGRATULATIONS[/size] on the conversion!
Because it gets hot here in Australia, I make and sell a product called Hoodjax. Hoodjax opens the top of your engine cover to let cool air in. They work similar to the cheapo cast alloy 'decklid offsets' but my design is removable; you can close your engine lid in seconds for rainy days. I hope hypovw (Mr Penrose) doesn,t mind... I have attatched a piccy of his 11-second drag car fitted with Hoodjax. My own cars and many customers over the last 10 years have seen engine bay temps drop by 20 or more degrees (to just a couple of degrees above ambient) and oil temps on air-cooled engines drop by 15C (sometimes more) degrees. I reckon Hoodjax will help lower your intake air temps
[Edited on 30/5/2005 by VWCOOL]
Pay your debts, CxxT
Memberboof2332
Threads: 120
Mood: Sympathetic
posted on May 31st, 2005 at 06:18 PM
If you do not want stand offs, as there is no air required to cool the motor as well, make a box section around the filter and have ducting running to it from either next to gearbox, a hole or vents in the deck lid, or do as I have and just cut out the small louvers between the hinge mounts and have the box go all the way up to this area...that would probably be the easiest as your filter is in the centre.
Matt
Membertype2nut
Threads: 39
Mood: sandy
posted on May 31st, 2005 at 09:16 PM
Well done. You must be stoked. And the Beetle looks great. I really like the look with those Porsche steel wheels.
I got my exhaust system back (85% finished) last weekend and will be in to my conversion after the June long weekend.
I can't wait.
For those who have finished, thanks for the inspiration!
Membersubaruboxer
Threads: 20
posted on June 1st, 2005 at 06:53 AM
Thank you all !
The 180 km/h was not the possible top speed, just what I wanted to do for the first ride. I expect something around
200 km/h. But, as you might know by now, it was with a slipping clutch. How fast will it be with a working clutch. The airfilter got to get a cover, so that the hot air from the engine does not get to it. I don´t like stand offs, so I have to do it a different way. That day was the hottest in May since 1875 in Germany. We had up to 32 °C , and in slow trafic it was up to 59 °C in the enginebay. But it is rare to get this hot overhere.
MemberBrad
Threads: 332
posted on June 15th, 2005 at 02:26 PM
have you got any pics of the front of your bug now it is finished ? How is the radiator cooling ?
Brad
Membersubaruboxer
Threads: 20
posted on June 16th, 2005 at 05:42 AM
Hi Buggy Brad,
it was 32 to 34 ° C hot those two days that I rode my bug for the first time. The temperature went down to 15 ° C right after that. The front of my bug looks still the same. The temp of my coolant was a bit to high, but that was because of the slipping clutch. Think about 3 000 rpm and the clutch is slipping 3000 times a minute on the surface of the flywheel.
The temps were 95 to 105, so that the fan was just a bit to often running. It was not running constantly. I can´t tell you yet how the cooling system is working, we got to wait til I have it on the road again with the new clutch.
MemberAnthiron
A.k.a.: Nicko McKay
The Baja Rejuvenation Begins
Threads: 310
posted on June 16th, 2005 at 05:16 PM
where is your radiator?:duh
1974 Chevrolet Luv
1970 MK2 Ford Cortina GT
Membersubaruboxer
Threads: 20
posted on June 17th, 2005 at 02:34 AM
Out front in the spare wheel´well.
MemberBrad
Threads: 332
posted on June 17th, 2005 at 09:54 AM
So any pics ? I am about to do one and need some good shots and pointers if possible.
Cheers,
Brad
Member72RSbug
Threads: 49
posted on June 17th, 2005 at 09:22 PM
don't mean to hack in but here's my BMW radiator in my Standard Bug
http://memimage.cardomain.net/member_images/4/web/844000-844999/844382_15_full.jpg
Super Administratorhelbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
posted on June 17th, 2005 at 09:59 PM
Congratulations.
180kph is scary. I certainly wont be game to go that speed in our bus when the EJ22 is in.
Membersubaruboxer
Threads: 20
posted on June 18th, 2005 at 02:33 AM
Brad,
the pics in my post ( My cooling system ) are not enough?
What do you need to see or need to know? I`d like to help you.
RSbug,
looks a bit strange to me, did you put it in sideways. To me it looks like you are loosing to much room that could be used for cooling down in the spare wheel well. Maybe this is just a bad angle in your picture.
Hellbus,
180 kph is not scary it is fun!
A good way to get additional air to the radiator is to use the horn grills and place a tube behind them directing the air to the radiator.
[Edited on 18-6-2005 by subaruboxer]
Member72RSbug
Threads: 49
posted on June 18th, 2005 at 05:15 AM
The way I placed it should be the same as it is placed in a BMW (drain pug at the bottom). And it goes down a fair bit from what is visible in the picture.With a small scoop under the car (+ I cut out a part like Zenjoe on Volksswap has) it should get plenty of air. Also placed a Peugeot ventilator in front of it.
[ Queries: 40 ] [ PHP: 15.4% - SQL: 84.6% ]
