[ Total Views: 1836 | Total Replies: 6 | Thread Id: 41334 ]
Author: Subject: new beetle speedo
Memberblutopless2
DAMSLO
Threads: 187
posted on July 5th, 2005 at 07:59 PM
new beetle speedo
anyone out there know how the new beetle speedos work? particularly interested in the type of signal that comes out of the gearbox to the speedo. Is it still a cable or is it electronic?
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
2014 Audi A4 Quattro
Memberjakjones
Threads: 3
Mood: Settled
posted on July 5th, 2005 at 10:44 PM
Hall switch screwed into the gearbox/diff area
Memberblutopless2
DAMSLO
Threads: 187
posted on July 6th, 2005 at 08:54 AM
so it works on frequency?
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
Membermscabrio
Cabriolet Queen
Threads: 142
posted on July 6th, 2005 at 12:46 PM
WHAT HAVE YOU DONT TO MY SPEEDO ?????? DON'T TELL ME THAT YOU HAVE TRIED TO PULL IT APART AND NOW CAN'T GET IT BACK TOGETHER ??????
And yes I am shouting ! Its' a womans perogative to shout whenever she feels like it
:punk:
Super Administratorvanderaj
A.k.a.: Andrew van der Stock
a suffusion of yellow
Threads: 438
Mood: In the family again
posted on July 6th, 2005 at 01:28 PM
The speedo is in the podule which contains most of the car's computers. If you disconnect power to it, you will need to reprogram everything from the door lock mechanisms through to alarm settings.
The speedo is a completely electronic unit, and if you're trying to adjust the 6 km/h bias out of it, go to 18" wheels with 55 profile rubber. That ends up being 100 km/h and 100 km/h. On the 16" OEM wheels, you'll be traveling at 94 km/h when it shows 100 km/h.
The Bentley manual is available electronically on CD - check http://www.newbeetle.org  to see if anyone is willing to part with theirs or where you can buy it directly.
Andrew
Memberblutopless2
DAMSLO
Threads: 187
posted on July 6th, 2005 at 09:51 PM
i havent done anything to your speedo.
1974 1300
1997 MK3 Golf GL
2003 NB Cabrio
2012 Golf VI GTI
MemberBug_racer
Threads: 16
posted on August 21st, 2005 at 10:14 PM
Its a hall effect type sender . Cables went out years ago . I think the 96 t4 was the last vw to use cable . The first was 87 200 T from memory , its possible that the UR Quattro used this system as well but havent worked on many so cant really check:crazy:
[ Queries: 40 ] [ PHP: 19.0% - SQL: 81.0% ]
