[ Total Views: 2078 | Total Replies: 4 | Thread Id: 417 ]
Author: Subject: IRS on 65 splitty
Membertwobus
Threads: 18
Mood: veedubbaddicted
posted on September 6th, 2002 at 04:54 PM
IRS on 65 splitty
Can Anyone tell me if you can use a 1973 type 3 gearbox in the conversion to IRS on a split bus.
I know you can use a post 1969 bug box , but someone said a type 3 box would work
Any Ideas Folks
MemberDasdubber
A.k.a.: Alan Agyik
DAS Resto Haus
Threads: 289
Mood: feeling fine...
posted on September 6th, 2002 at 06:19 PM
Sorry I can't answer your question, but try giving the boys at Indian Automotive a call or an email, they should definitely know if no-one here can help.
Alan
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on September 6th, 2002 at 09:43 PM
Yes you can use a Type 3 IRS box in an IRS conversion for a split screen, but you will need to use the splitty nose cone and hockey stick.
Same goes for the Beetle box too.
FAHRVERGNUGEN;
Membertwobus
Threads: 18
posted on September 7th, 2002 at 02:26 PM
Thanks for the info, I had a look at a suitable type 3 this morning. Is $500 an OK price for a just out of rego 1600 T3 with a good engine and gearbox?and a pretty good body?
MemberMenangler
A.k.a.: Dave Becker
Threads: 309
posted on September 7th, 2002 at 08:43 PM
I bet 3rd gear syncro in the box will be fzzzrt, in the Type 3's they always seem to be.
$500.00...........mmmmmm bit hard to say without looking at it, I gues it would be OK if you can sell what you don't need and get the parts you need for nothin!!
FAHRVERGNUGEN;
Membertwobus
Threads: 18
posted on September 8th, 2002 at 07:21 PM
Thanks Dave, I'll check out the third gear syncro!.I still havn't got the wifes impromata to buy yet another VW
Memberhumpty
Threads: 139
Mood: Totally boosted!
posted on September 9th, 2002 at 05:40 PM
TIII Box in a Splitty
Yes it will go...but!
The ratios aren't that great if you are gonna run a mild engine....If you have more torque, then it will be ok......Use baywindow bus bits to get it in. From the spring plate back and use the TIII axles & mix & match the CVs. TIII inner, Bus outer. Then all you have to do is mod the diagonal arms to fit...The splitty is narrower!...Been done, takes a bit of work though....If you have the bucks give Indian a call...Kimms kit is very good, if a little pricey...But he has done a lot of work on the kit!
FUCH your early!
http://www.noh2o.org/
Membertwobus
Threads: 18
posted on September 9th, 2002 at 07:34 PM
Humpty
Thanks for that, I'm using a mildish type 4, 2 litre, I spent twenty years doing architectural metalwork and prototyping various products so I think Ive got it figured out, Ive also had experience building sidecars both road and race and the rear end of a Kombi seems simple by comparison but again thanks for the info,Theres no substitute for experience.
[Edited on 9-9-2002 by twobus]
Memberhumpty
Threads: 139
posted on September 10th, 2002 at 06:47 PM
Good luck...Seems you have it in the bag!
My brother is pretty clever too!...He did it to his 15window deluxe a little while back...TOTALLY transformed the way that sucker cruises...!
Check his bus out on my site...Members section.
His story is called "The story of Choppa, Burt & Rex"
FUCH your early!
