| [ Total Views: 1144 | Total Replies: 22 | Thread Id: 4342 ] |
kombi_kid
Good Kid too many projects
Threads: 341
| posted on March 12th, 2003 at 09:01 AM |
merc rims
hey
what are the merc rims that fit kombi's??
and how do u measurer the PCD of things???
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 15th, 2003 at 11:55 PM |
The PCD (Pitch Circle Diameter) is the diameter of a circle drawn through the centre of all of the studs. On vehicles with even stud numbers, just
measure from the centre of one stud, to the centre of the opposite stud. I still haven't worked out a simple say to measure odd-numbered stud
patterns though, but measuring the radius (from the middle of a stud to the centre of the wheel) may be somewhat easier, then double it.
From memory, late kombi's are 112 mm, 4-stud beetles are 130mm and I don't have a clue what wide-5's are.
I'd happily tell you what Merc wheels I'm using, but the offset isn't ideal, so you'd want different ones to what I've got
anyway.
Kruizin Kol
tracash242
Threads: 29
| posted on March 16th, 2003 at 10:09 AM |
hi the ones your looking for should be ,ET37,stamped on them meaning 37 mm offset ,if you want to go low you can put ,ET49,on the front to give a bit
more room against the gards but on the front only .ET37 have to go on the rear,i am looking for some at the moment.?
Phil74Camper
Head in the Clouds
Threads: 193
| posted on March 17th, 2003 at 09:59 AM |
There's quite an easy way to work out the PCD of a five-stud wheel.
Measure the distance between the centres of any two adjoining studs (say the bottom two), then multiply that by 1.7013 to get the PCD.
The reason is that you can contruct a right-angle triangle between two of the studs, with the angle at the centre equal to half of 360/5, or 36
degrees. From the old trigonometry, sin 36 = y/x where y is half the stud separation and x is the stud to centre distance (the hypotenuse). Double the
size of the triangle and you have the total stud separation and the PCD as y and x. So to get x, multiply the stud separation y by the inverse of sin
36, which is 1.7013.
Hope someone can confirm my old high-school trig maths - its a bit rusty!
twobus
Threads: 18
Mood: veedubbaddicted
| posted on March 17th, 2003 at 10:36 AM |
Kombi Kid
Check out Audi rims as well as they are also 112 PCD and have the same centre bore diameter so don't need a bore reducer, If you use merc rims
without centre bore reducers the load is taken on the studs.
Twobus! when one is not enough
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 17th, 2003 at 07:25 PM |
There are plenty of wheels around that are not designed to place the load on the hub and therefore place the load on the studs. While I agree that a
wheel designed to place the load on the studs is better, I wouldn't be too concerned about it, especially on a kombi with 14mm studs.
The Mercedes (aftermarket) wheels that I looked at recently only accepted 12mm studs, which may be a problem if you are not confident about redrilling
them, but any half-decent machine shop should be able to do this for you.
Ps. My Merc rims are et55's, which do fit, but won't accept wider than a 205 (maybe a 215) tyre - I have maybe 6-8 mm clearance between the
tyre and the trailing arm. Plenty of room on the outside though.
Kruizin Kol
kombi_kid
Threads: 341
| posted on March 17th, 2003 at 09:31 PM |
i wouldnmt wont to go wider then 195's on the back and 185's on the front so i dont scrap but i think i need 16's so i can get about a
50 profile on it!!!
rhys
helbus
A.k.a.: Pete S
Threads: 312
Mood: In the thinking chair
| posted on March 17th, 2003 at 11:14 PM |
I got rims for HELBUS 16x7. Umm if I remember rightly they are 205/55/16
They were to suit Merc, and the stud holes had to be drilled out to suit the bigger VW studs.
It was quite easy I just went to Canterbury rd tyres and I chose the style and they fitted them! I paid for them. Then I drove away
kombi_kid
Threads: 341
| posted on March 18th, 2003 at 06:24 AM |
yer i can make up adaptors easy as (my teacher at school can make em in no time he tells me) so hopefully i can find some cheap 16's!!!
rhys
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 19th, 2003 at 06:46 PM |
Argh!!! Why are you still talking about using adapters Rhys? There are wheels around that have the correct PCD and don't need to use an
adapter......
Kruizin Kol
kombi_kid
Threads: 341
| posted on March 20th, 2003 at 06:25 AM |
i thogutht they only came in 15's???
rhys
daz67
A.k.a.: Darryl Hall
Qld Manx
Threads: 25
| posted on March 20th, 2003 at 09:59 PM |
Can anyone confirm if BMW 5 stud is the same as Kombi stud pattern?
I have a set of 4 X 17" BMW X5 Alloy wheels with Brand new tyres For Sale $1000
Will get Pics if they are of interest to anyone?
manx020
Threads: 2
Mood: asleep
| posted on March 22nd, 2003 at 11:48 AM |
rhys, i believe BMW 5 stud pattern to be the same as commodore. not even close to bay kombi pattern. falcon is closer, but still needs to be modified
to suit. i have just bought a brand new set of alloy 5 spoke 15x7 wheels. i waited 8 weeks for them to be made... but they fit with no mods &
included the 14mm metric nuts needed for the kombi.
rick
manx020 |
11CAB
If ya got it....Baja it
Threads: 321
Mood: Beach'n
| posted on March 25th, 2003 at 09:18 PM |
Sorry Darryl, BMW definately don't fit kombi's. I'm using ford mags on mine. the ford PCD in 114mm, and kombi PCD is 112, i had my
wheels offset drilled 1mm to fit.
Graham
65 Meyers Manx
68 Country Buggy (KO 367)
68 Country Buggy (KO 669)
68 Country Buggy (KO 789)
68 Country Buggy (KO 815)
68 Baja Bug
76 Baja Kombi Twincab
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 25th, 2003 at 09:33 PM |
Rhys, don't use adaptors, they are illegal.
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 26th, 2003 at 05:35 PM |
Rhys, try looking for some aftermarket Merc alloys, but make sure that the offset is correct for your purpose.
Kruizin Kol
kombi_kid
Threads: 341
| posted on March 28th, 2003 at 06:16 AM |
what offset should i be looking for???
rhys
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 28th, 2003 at 03:10 PM |
Easiest way to work that out is to measure what's on it already, and work out how much more room you have to play with. I've got a great
article here somewhere, I'll dig it out for you.
Kruizin Kol
kombi_kid
Threads: 341
| posted on March 28th, 2003 at 04:46 PM |
thanks col
rhys
KruizinKombi
A.k.a.: Col
Threads: 104
Mood: Indifferent
| posted on March 30th, 2003 at 12:33 PM |
Rhys, does it make sense now?
Kruizin Kol
kombi_kid
Threads: 341
| posted on March 30th, 2003 at 07:38 PM |
yer- thanks col
rhys
1303Steve
| posted on March 30th, 2003 at 10:54 PM |
The stock Kombi wheel is 14 x 5.5 with an ET of 39, you should be able to work out what will fit by seeing how much clearance you have with a stock
wheel.
1302Steve
kombi_kid
Threads: 341
| posted on March 31st, 2003 at 10:38 PM |
yer have been checking out a few wheels just from the wrecker non good so far
rhys
fish
Threads: 32
Mood: just cruisin
posted on April 19th, 2003 at 05:30 AM |
merc rims
how did you go with the rims. we still have 5 for sale. going cheap. cheers, fish
| Error |
Drink and drive your a bloody idiot!!! make it home you'r a legend !!!!
humpty
Threads: 139
Mood: Totally boosted!
| posted on April 19th, 2003 at 03:41 PM |
16"s
Guys...I ran 16x7 of a MERC with 205x55/16 on the front & 225x50/16 on the rear. The ET from memory was 47 and they are a perfect fit! No rubbing,
tram tracking or weird wear patterns. Note that the Lug nut "cup/taper" on MERC rims is different (made for 12mm studs) than on the Bus
(14mm)....They don't seat properly...I haven't had any problems but the cops/insurance guys might if they every found out!
fish
Threads: 32
Mood: just cruisin
| posted on April 20th, 2003 at 05:02 AM |
thought ild bump this to the top again cheers, fish
kombi_kid
Threads: 341
| posted on April 20th, 2003 at 08:42 PM |
hey
i bought mags off my dad so ill pass thanks anyway fish!
rhys
