[ Total Views: 715 | Total Replies: 6 | Thread Id: 44346 ] |
72RSbug
Threads: 49
posted on September 29th, 2005 at 08:10 PM |
difficulties starting...?
anybody else have this problem with their EJ20's?
My EJ20TT (when cold) needs about 8-10 tries before she starts and when (slightly) warm she starts up first time every time.
could the problem be caused by not having a VSS installed yet?
ricola
Threads: 9
posted on September 29th, 2005 at 10:11 PM |
I seriously doubt it ,when you aren't moving there wouldn't be a signal for the ECU anyway... Could it be a faulty temperature sensor?
Rich
pete wood
posted on September 30th, 2005 at 04:24 PM |
what starter are you using?
I've had issues on and off with starters not having enough guts to turn mine over when hot. In the end I have a dedicated earth strap going from the
negative pole on the battery to one of the starter bolts. It works great now.
72RSbug
Threads: 49
posted on September 30th, 2005 at 07:14 PM |
I'll put an extra ground wire on the starter and hopefully that'll solve it, thanks for the tip pete wood.
this is the starter I'm using, it's a high torque one that is smaller then stock so it'll clear the primary turbo.
ratbug
A.k.a.: Andrew Todd
aka toddy101
Threads: 30
posted on September 30th, 2005 at 08:07 PM |
I had this exact problem when i didnt have the START signal from the key switch going to the ECU. Its purpose is to give a bit of extra fuel when
cranking to help it fire up. When it was warm it would start instantly.
72RSbug
Threads: 49
posted on September 30th, 2005 at 09:02 PM |
any idea what pin on the ECU needs to be hooked up to the start switch?
ratbug
A.k.a.: Andrew Todd
aka toddy101
Threads: 30
posted on September 30th, 2005 at 10:15 PM |
Nah, mine is N/A so the pins are different, but just before it goes into the ECU (10cm or so) it will be a fat heavy gauge wire (same size that goes
to the starter solenoid). This is assuming the EJ20TT is the same. Mine was RED/Yellow. Do you have a wiring diagram? it should show it (also goes
through the clutch or inhibitor switch so you can't start it in gear)
