| [ Total Views: 611 | Total Replies: 3 | Thread Id: 4610 ] |
jakriz
Threads: 46
Mood: 2 headed
| posted on March 21st, 2003 at 11:53 PM |
Can u Weld Ceramic Coated items?
I have a 1.5 inch merged header & hideaway exhaust that I was going to have Ceramic coated, but I have it all welded up as 1 item as it returns as
a centre mounted outlet like the Porsche Boxter & I find it easier to take on & off this way. I was told that I couldn't have the exhaust
coated the same way inside & out as the header as the baffles wouldn't take it. So I thought that I could just cut the muffler off , have it
done seperately, (outside only) then weld it back on after. It was mentioned by a friend that u couldn't weld something that has been Ceramic
coated. Is this correct?
regards
Jak
Congratulations to Ben Durie for breaking the hillclimb record at Ringwood in his stroker beetle!
OvalGlen
Threads: 46
Mood: Change
| posted on March 22nd, 2003 at 01:59 AM |
you will get more informed welding advice than I,
but I believe that if you just grind back ceramic for the weld then no worries.
Could you weld Flange joint on so bolt together later?
Could you overlap the pipes so that just a few small stitches are required to secure later.?
Regards,Glenn>
Andy
Andy's Adventures
Threads: 181
Mood: Happy Man
| posted on March 22nd, 2003 at 09:02 AM |
When I had my exhaust coated I was assured it could be welded afterwards. Never tied it though.
http://www.hpcoatings.com/
:thumb
68AutoBug
| posted on March 22nd, 2003 at 12:06 PM |
Why are You having Your exhaust system Ceramic coated?
Stop Rust?
Make it last longer?
and is it expensive?
regards
Baja Wes
V6 Baja Pioneer
Threads: 94
Mood: Content
| posted on March 22nd, 2003 at 07:54 PM |
From what I understood, the ceramic coating actually improved the weldability.
Best to check with whoever is going to coat it, as I am sure not all coatings would be the same. I have welded a ceramic coated muffler to an uncoated
exhaust pipe before, and didn't have a problem.
1303Steve
| posted on March 22nd, 2003 at 08:07 PM |
My cermamic coated system has had a few leaks at the flanges and I welded them up no worries, it just destroys the coating in that area.
1302Steve
jakriz
Threads: 46
Mood: 2 headed
| posted on March 23rd, 2003 at 06:07 AM |
Thanks for that Steve, thats what I thought.
Jak
vw54
| posted on March 23rd, 2003 at 08:22 AM |
For a better welding job i suggest that you grind the coating off in the weld area first....
The ceramic coating will act like a slag and probally flow into the weld filler material and give a slag inclusion.
This will weaken the weld,
