| [ Total Views: 568 | Total Replies: 3 | Thread Id: 4642 ] |
kombi_kid
Good Kid too many projects
Threads: 341
posted on March 23rd, 2003 at 06:50 PM |
help computer junkies
hey
my bro stopped playing Age of methology (latestgame) and when he came out opf it everything is really really huge all the screens everything.
i cant change any settings because i cant navigate my way around!!! can even reload windows
got any idea what it is??? (not sure if its the game or not)
rhys
Bizarre
| posted on March 23rd, 2003 at 06:59 PM |
try booting in "safe" mode
kombi_kid
Threads: 341
| posted on March 23rd, 2003 at 07:10 PM |
hey
im running windows 98 SE (just for the note)
rhys
p.s. not very comp illiterate how do u do that?
mhbourke
Threads: 6
| posted on March 23rd, 2003 at 07:31 PM |
hi rhys just go into your control panel and check what your monitor is set to some games change these settings and you have to reset them.failing that
try and load default settings.you should be able to do this when rebooting (be quick) there is a message saying press to enter setup"so and
so"button or buttons. these all vary from program to program and mother board to mother board.once into setup there should be a menu to lrestore
to last setup or as was said safe mode:sandrine
kombi_kid
Threads: 341
| posted on March 23rd, 2003 at 07:37 PM |
hey
thanks as stated above i cant move the windows far enough (run out of screen) to be able to change the setting ie 600x800 etc
rhys
Bizarre
| posted on March 23rd, 2003 at 07:44 PM |
when you first boot you should be able to hit "F1" or some other key and this gets you to "safe" mode.
Safe mode is a basic mode that cant run anything fancy ie 16 colour only etc.
You can at least get there and set up a basic run and then re boot it in "normal" ie dont hit "F1"
haugmichael
Threads: 28
| posted on March 23rd, 2003 at 08:29 PM |
Start your computer as normal and wait until you see the POST. (this is where you see numbers ticking over on top left hand of screen). Your computer
then goes and looks for your disk drives and this is when you should hear a beep. This is when you press the F8 key on your keyboard. Now select safe
mode.
or you could try this
Boot until you come to your desktop. Right click your mouse button on any blank area on your screen then click on "Properties" then click
on the "Settings" tab. now change the tab settings to 600 x 800 and then click on OK. You will most likely get a message " Do you want
to restart your computer" click on "Yes"
kombi_kid
Threads: 341
| posted on March 24th, 2003 at 03:26 PM |
fixed it guys!!!! its either F5 or F6
rhys
